33 Pages «<2122232425>»
willz buildz Options
willz
#441 Posted : 24 October 2013 16:09:13
Active Service Medal: 500 post active service MedalTurquoise Medal: Turquoise Medal for model making know-how contributionOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of Honour
Cheers all for the kind comments, very much appreciated.
As for a diorama Hans, its something that I've been thinking about, but for the mo theirs too much other stuff to do.
So onto the next mini project, as the pic below shows I`m just about to start making my next addition to the build, but I`m going to keep it a secret till I`m up and running at the weekend, I think it may be a little obvious what it is but guesses are welcome. Cheers lads (and lasses)
willz attached the following image(s):
willz
#442 Posted : 25 October 2013 03:31:31
marked out the for cutting
willz
#443 Posted : 25 October 2013 14:29:43
small update on the anchor
willz
#444 Posted : 25 October 2013 21:13:45
OK onto the spades, the pics below show the spades in the making, the only point of concern here is when fitting the spades to the anchor they must just fall into the cut-outs (pic five shows the spade too tight), because the grain of the ebony runs with the shaft of the anchor so if the spades were only slightly tight it would split the end off the anchor tips.
Next up will be the anchor stocks, I did think of making them out of ebony but decided against it in favour of walnut, the ship is an all natural finish and I personally like the contrast between the black of the ebony and the brown of the walnut.
Cheers all
#445 Posted : 25 October 2013 21:23:28
BigGrin Lovely work Wilz BigGrin Rgd Martyn
#446 Posted : 25 October 2013 22:51:39
Beautiful....Love Love
#447 Posted : 26 October 2013 01:00:16
willz
#448 Posted : 26 October 2013 16:32:24
Cheers lads, appreciated.
Started on the anchor stocks when disaster struck, the light in my magnifier popped, all work now suspended till replacement arrives. (think I`ll go to the pub)
Foz
#449 Posted : 31 October 2013 11:51:10
Beautiful detailed work as always Willz.
Foz
sparks
#450 Posted : 02 November 2013 21:34:12
Fantastic work on the anchors Willz,
Shame about the magnifier lamp.
willz
#451 Posted : 16 November 2013 23:24:43
Cheers all appreciated
New light arrived, time to get back to it, decided to leave finishing off the anchor, going to do all four together at a later stage. Instead turned my thoughts towards the water cutter, If I make that then I can finish off the figureheads trailing ribbons. Ok the pics below are of my new light (yippee) and the start of the water cutter, I'm making the water cutter out of 5.5 mm exterior ply, I bought a full sheet of 8ft x 4ft at the start of the build (still got loads of the stuff), on a 1/72 scale the piece measures in at 6.5 mm at the bottom and back and 4.5 at the front and top. I cut out the shape and then sanded in the taper, I will be cladding it in 1 mm walnut so had to get the original down to 4.5 bottom and 2.5 top and must admit found it a little tedious, got to the stage where I'm sticking on the walnut, both sides will be done simultaneously as I stick a piece on one side the corresponding piece will be applied to the other, this balances out the piece and helps to prevent any warp
Foz
#452 Posted : 17 November 2013 11:02:00
Glad to see you back on track with your new lamp.
Lovely work as always
Foz
sparks
#453 Posted : 17 November 2013 13:21:08
Nice to have you back Willz, I've misse drooling over your work. BigGrin
#454 Posted : 17 November 2013 21:55:10
#455 Posted : 18 November 2013 11:40:48
Gotta love work Willz, gotta love your work.Drool
willz
#456 Posted : 19 November 2013 01:05:24
Cheers all appreciated.
On with the build.
The pics below show the prototype for the water cutters curly bit, its construction is two pieces of 1 mm walnut in the centre running cross grain with two bits of .5 mm walnut on the outer edges running with the grain. As you can see the curve is OK but the thickness is wrong, as it reaches the front it tapers. Thought about sanding the curve to the correct width but this will bring it into the inner cross grain, so into the skip it goes. Will have to laminate the piece first without the bottom strip, sand the cross grain to the tapered thickness minus .5 mm then stick on the missing strip.
willz
#457 Posted : 21 November 2013 03:38:00
Cladded the water cutter and tapered. Rounded off the top piece near the figurehead as per photos studied. In hindsight dont think it was necessary to replicate all the bits but again just good practice
#458 Posted : 21 November 2013 07:59:55
Stunning Work matey
J
#459 Posted : 21 November 2013 08:38:15
BigGrin WOW bril work looks stunning BigGrin Rgd Martyn
Foz
#460 Posted : 21 November 2013 11:27:27
Stunning work as always, look forward to your next installment.
Foz
Guest (11)
This page was generated in 0.458 seconds.
