Hi all, This is first major build so sorry if the answer is obvious but... Should the bottom of the gunports be level with "the sea" or follow the strakes curves? I have looked at piccies and can't tell for sure - some look like they do and others don't.
KevS wrote:Hi all, This is first major build so sorry if the answer is obvious but... Should the bottom of the gunports be level with "the sea" or follow the strakes curves? I have looked at piccies and can't tell for sure - some look like they do and others don't. Hi Kev, nice to see you on the forum... I too am building this beautiful ship and all of my gunports, tops and bottoms run parallel to the water line.... Hope this helps. Regards Alan
Good morning Alan,
Thank you for the warm welcome and for your comments. It is nice to have someone of your skills point the way!
Many thanks
Kev
