6 Pages <12345>»
Build Diary of Amati 1/200 Bismarck Options
B Johnson
#41 Posted : 06 November 2013 20:15:20
Virtue86 wrote:
looks great ben, will be looking forward to seeing a few more pictures. This log will be a good reference for me when i come to start mine once the hood is finished. That might be some time though.
Yeah like wise your build log of the Hood will be helpful for me, hope you get some more pics up soon.
Current Builds: Amati 1/200 Bismarck, Airfoil 1/600 HMS Nelson
To Build: Amati 1/200 HMS Hood, Amati 1/250 Titanic, Artesania Latina 1/48 HMS Surprise, Artesania Latina 1/50 Scottish Maid, DeAgostini 1/84 Sovereign of the Seas
B Johnson
#42 Posted : 06 November 2013 20:31:42
I carried out the next round of sanding and filling, once this had been done I applied another coat of primer, checked the hull and done some more filling and sanding, this process was done several times until the hull was smooth.
I also added the sea chest grates and the metal parts supplied to line the portholes, these had a rounded end which was sanded back to give a perfect porthole.
#43 Posted : 08 November 2013 22:09:33
Looks like you should end up with a beautiful finish to that hull.... very nice indeed....Cool Cool
B Johnson
#44 Posted : 11 November 2013 21:09:26
Thanks Alan, there has been a lot of work on the hull! I should have used a sanding sealer before priming the hull, this way it would have got rid of any pin holes and gaps but I ended up painting, filling, painting, filling and so on, but I think I have ended up with a good finish.
Ben
Foz
#45 Posted : 12 November 2013 10:51:01
Hi Ben, your hull will look really great, look forward to your updates.
Foz
#46 Posted : 13 November 2013 16:04:07
Hi Ben.
Looking really nice.
Dose the amati kit give you all the paint options on the hull and super stucture. I am doing hatchettes version of the Bismarck, it came with three different paint options. Look forward to seeing your progress Ian.Cool BigGrin
B Johnson
#47 Posted : 13 November 2013 21:00:37
ian smith wrote:
Hi Ben.
Hi Iain,
Yeah its the Hatchette partwork i'm building but the model is produced by Amati. Yeah the only problem with the instructions are that they follow one scheme, i'm applying the baltic strips to the whole ship but there is no guidence on how to do it.
Ben
#48 Posted : 14 November 2013 13:44:56
Hi Ben.
I was going to do the Baltic stripes all the way up. The only way I thought you could do it was by hand painting them on before you fix the wooden deck boards on.there are a lot of super structor fittings that have to be painted round and over if you go that way. In issue 120 of hatchets original build there was a big fold out painting and rigging guide did you get this with your kit. I decided in the end to do the stripes up to the edge of the decks.
I hope this of help to you ian
B Johnson
#49 Posted : 17 November 2013 17:18:52
ian smith wrote:
Hi Ben.
Your build is looking really good, your almost there lol
Yeah I got those big plans, however I think the lines on the plans are slightly out, looking at photos of the real ship with the stripes applied the plans template don't quite match. I have started to paint the stripes on the funnel, photos to follow later on. I left the funnel un-built, masked off the area then air brushed. After I started to add the detail and hand painted these areas. However this technique won't work for the bridge and front part of the ship because i've already build it and added all the detail!
B Johnson
#50 Posted : 17 November 2013 17:39:44
I wasn't happy with shape of the anchor ports because the shape didn't match photos of the ship so I decided to beef them up using strip wood cut into small lenghts then glued in place, after it was dry I added another layer and so on, after i was happy with the rough shape I used filler and sanded back to give the final shape
I also added the detailed part at the bow of the ship, this was glued together and sanded
I made a start on the deck edge detail using strip plastic
I have also decided to plank the whole ship as the kit supplied deck is ok but there are some issues with it. I have bought lime wood strips in 1mm 1.5mm and 2mm sizes. From the photo you can see a practice I carried out, I mixed black acrylic paint with pva glue to get the caulked and tar seams effect, to the right of the photo is the kit supplied deck.
#51 Posted : 17 November 2013 18:58:37
planking will look good. some nice attention to detail looking forward to the end resultCool
B Johnson
#52 Posted : 17 November 2013 19:56:03
Thanks Jase,
I've noticed some people have talked about a hydrophone on the Bismarck hull, I have no information on this, just wondering if anyone can give me details on it like the position on the hull and size?
#53 Posted : 17 November 2013 21:15:42
BigGrin Hi B Johnson
The link below may help you i think its located about a third along the hull from the bow
http://forum.model-space...osts&t=6271&p=9
#54 Posted : 17 November 2013 21:16:36
Hi Ben.
Coming along nicely. Look forward to seeing your progress Ian BigGrin
#55 Posted : 17 November 2013 22:10:43
Really nice work Ben, well done.....Cool Cool .. Look forward to seeing more of this build....Cool Cool
claret
#56 Posted : 19 November 2013 08:51:40
Hi Ben,
That is one nice build.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
B Johnson
#57 Posted : 30 November 2013 20:52:37
Thanks Andy, not sure if i'm going to add this to my build yet, all these added extras means its going to take a life time to build!LOL
Ben
B Johnson
#58 Posted : 30 November 2013 21:01:44
The hull is almost ready for its final coat of primer and finishing colours, but before this I have added a little extra detail, I've used fuse wire to represent the eye brows above the portholes and detailing at the stern. The funnel has also seen some more attention, I wasn't happy with the molded pipes at the top of the funnel, so I've cut them all off and replaced them with metal tubes cut to size, I used the albion alloy metals for this. I have also sanded off most of the molded detail on the funnel to replace it with photo etch from the eduard set for the trumpeter bismarck. I will also mask and paint the baltic strips at this point.
Foz
#59 Posted : 30 November 2013 21:37:11
Hi Ben
Some very nice detail there, love the build. Keep up the good work and i look forward to your progress.
Foz ThumpUp
#60 Posted : 30 November 2013 23:30:27
Some seriously fine detail being added there Ben and it's this kind of detail that makes all our builds unique...... impressive work..... Love Love
6 Pages <12345>»
This page was generated in 0.187 seconds.
