Zero Painting Options
The Borg
#1 Posted : 19 November 2013 08:29:06
Rank: Newbie
Hi,
In the instructions the fuselage skeleton is painted Blue. But can someone tell me what is the ACTUAL colour/shade to paint? And will this colour be used to paint the wing ribs etc?
Any help would be greatly appreciated.
Thank you Confused
#2 Posted : 19 November 2013 09:10:49
The Zero discussion section covers the majority of aspects of this model, here is the discussion about aotake blue..
http://forum.model-space...aspx?g=posts&t=7779
#3 Posted : 19 November 2013 09:49:35
Hi Borg,
Depends on how you plan to display your model what parts you decide to paint. As for the colour I used mix of Tamiya x-13 Metallic Blue and Tamiya X-25 Clear Green.
You can see the effect on this link.
http://forum.model-space...osts&t=3475&p=4
experten
#4 Posted : 19 November 2013 17:11:18
Groups: Registered, Official Builds
For mine, I used Lifecolor Aotake. It has the advantage of being waterbased, so cleanup is simple. however, the flip side of that is that it requires a primer to be used.
experten attached the following image(s):
Tired, Old, and Cranky!
kwakermad
#5 Posted : 21 November 2013 18:54:39
What is everyones recommendations as regards what primer to use? Thanks
Bob
Builds in progress
1/12 Spitfire (Deagostini)
1/8 McLaren (Deagostini)
1/16 Stuka (Hatchete)
1/16 Zero (Deagostini)
experten
#6 Posted : 22 November 2013 04:11:52
Well, I guess saying whatprimer I used might have been helpful! I use the Tamiya Clear Metal primer, because it allows the natural aluminum so show through, which gives the Aotake a bit of iridescence.
#7 Posted : 22 November 2013 09:44:36
BigGrin Hi Experten
The clear primer by Tamiya is not available in the UK an alternative is made by Mr Hobby called Mr Hobby Clear which should do the job. Its available from MDC link below
http://www.modeldesignco...uction/_486491/1/Primer
This page was generated in 0.164 seconds.
