Beautiful work Claret Spence
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Hi Guys, Many thanks for the kind comments. Will try and post a few pics over the week, need to progress on the sots  . Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
Hi, A little more done. Firstly I frosted the core reactor windows (must be leaded windows  ) with 1200 wet and dry.  and after sanding...  Regards claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, For the lighting effect, I boxed all the instrument panels and core windows to be lit up with 2mm styrene card behind the panel and used aluminium sticky foil to stop light escaping.   I had purchased the VoodooFX lighting kit which i soldered up using different leads, 11 LED's in total so far and 5 more to be constructed and soldered to the PCB. I tested them this week and all the LED's came on!!!! Dry fitted a couple of panels to see how they look and was impressed with the result. especially the core window, the led changes colour every few seconds.      Thats all for now. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
 Rank: Pro Groups: Registered
Joined: 05/12/2012 Posts: 258 Points: 754 Location: manchester
hi claret very impressive great build  benny.
Looking better than the original set!! J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Stunning work Claret, all credit to you.... Regards Alan
 Hi Claret Love the lights they defo bring her to life regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Benny, Jase, Alan & andy, Many thanks for your nice comments. I was relieved all the LED's worked and surprised how well they bring the model to life. Still a lot to do before I can glue the interior in place and set all the lighting up. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Very repressive Claret. Look forward to your progress.
Foz
Absolutely fantastic Claret, the lights will look amazing, well done Steve
Thanks Steve. Much appreciated. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, Some more progress. The PE kit has 5 microphones with it and suggests installing them on the frame uprights. however, checking the film stills, the only microphone I can see is on the side of the back instrument panel. I proceed to cut the microphone one and glued it onto 2mm styrene. Once the glue was dry i cut and sanded the styrene to the shape of the mic. I then primed and painted matt black. I used 0.35mm solder wire coiled around a 1mm dry bit and primed, painted black and glued to the mic. result below.  And glued in place...  Regards claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, I have made three air cylinders from 5mm plastic rod, 1mm brass rod and wire. Painted and installed under the bunk. I used de-soldering braid for the strap to hold them in place. result below:  Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, Although I am lighting the model extensively, I have not wanted and wires to come out of the model to the battery and switch. To overcome this, I am going to put the battery into the access tunnel which is accessed by the hatch seen in previous photos and a hatch at the rear of the craft. the later is going to be the point where i can switch the lights on and house the battery. I have hinged the rear hatch and spring loaded it so it shuts back when the battery is in place etc.  It works really well, and opens and closes with not to much force. Regards claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, Just a couple of dry assembled photos to put everything into perspective.   Thats all for now. Thanks for looking in. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Stunning, some beautiful details being shown on this build Claret, credit to you..... Regards Alan
Hi Alan, Thanks. This has been a nice distraction from the SOTS Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
HI Claret. A stunning build and a real eye for the detail. Really look forward to your progress. Regards Foz
Guest (6)
