Joined: 25/03/2013 Posts: 204 Points: 620 Location: Kajang , Selangor , Malaysia
Hi, Peter , Thank you Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
Due to whatever reasons the under-size eye-bolt or eye-pin is/are under-supplied which is not easy to work with. I have to make some myself. The pics tell all. yzwong attached the following image(s): Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
Build cont. with the rigging of the guns yzwong attached the following image(s): Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
Build cont. with issue 51 and issue 52 Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
Looking beautiful, you must be proud.
Issue 51 - installing the rudder yzwong attached the following image(s): Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
Issue 52 yzwong attached the following image(s): Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
Hi, john , thank for having a quick look at my build . Thank again Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
 looking great Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 07/06/2013 Posts: 144 Points: 415 Location: New Zealand
Learned quite a bit from this. Thanx. I've decided not to use the supplied wire on the carronade as I've noticed that ropes are used on the original. It will take some work but I want it to be authentic.
Coming along very nicely Yzwong.. well done.... Regards Alan
Thank Andy Thank Sinbad Thank Alan Deck support beams complete install. yzwong attached the following image(s): Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
I trim off 1 mm all the 5 mm strips to be use in the quarterdeck planking. Below are some pics of it. yzwong attached the following image(s): Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
Quarterdeck planking in progress. yzwong attached the following image(s): Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
Coming along beautifully Yzwong, look forward to seeing more.... Regards Alan
Beautifully neat work, well done Steve
Thank, Alan for your beautiful words Hi, Steve thank for your beautiful words. Quarterdeck planking completed yzwong attached the following image(s): Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
HI Yzwong. You have a lovely build there. Very nice work. I look forward to your progress. Regards Foz
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
Nice neat deck there Yzwong. Keep up the good work. Peter. Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Deck looks great jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Guest (14)
