 Rank: Pro  Groups: Registered
Joined: 07/06/2013 Posts: 144 Points: 415 Location: New Zealand
OK.After some meditation and encouragement from my fellow modelers I started the planking today. As per instructions I started with the Stern Gallery planks. After reading them 2 or 3 times I thought "No sweat". Well, was I wrong. First thing I find when I did a dry fitting of the middle plank was that the 2 double supports (32) are holding the plank about 2 or 3mm above the middle supports, which means it will give the planking a curved effect. I'm guessing this is not the desired effect.
Hi Sinbad, If you can post a pic of this it would be a big help, I do have a good idea of what you are talking about though. If the the 2 double supports are holding the planking too high then the central ones may not be pushed down far enough into the bulkhead (31). If they are pushed in properly then a sanding off to level the 2 double supports with the rest should do the trick. On another point - you need to make sure that the bulkhead (31) is pushed down as far into the slot as it can go as some builders (me included) have ended up with this sitting too high and needing to be reworked at a later stage. Post a pic and lets have a look at it Steve
Hi @Dominic, I got the impression that he means that while a plank is laid across all the supports the plank is in fact only touching the outer supports at each end (the double ones) then there is a small gap under the plank on all other supports between the 2 outers? Steve
Ahh, Im with you now, yes you do need to make the planks follow the inward curve of the supports, If id seen a pic I would have realised right away Steve
Thanks for the response guys and the advise. Since posting my query I hsve seen another post where some have had the same problem. AS far as I'm aware every thing is 'pushed down' etc. Anyway if it weren't it would be a job to unglue it all. It's not really a biggie as I can use some thin wood shims or cardboard. Thanks again.
Hi Sinbad, What Dominic and I were saying is you don't need to use shims under the planks, the planks are meant to curve to match the supports so when viewed from the stern with the ship the right way up the planking will curve gently upward. This is why you need to pin the planks as they will want to lay straight. Steve
Whewww ! Thanks Stevie. I had a feeling but wasn't really sure. Lucky I didn't start sanding. They don't really make this clear in the instructions. Thanks again.
