27 Pages «<2324252627>
The Military Quiz Options
petpole
#481 Posted : 21 November 2013 22:38:38
Well done Benny, over to you.
Peter
benny b
#482 Posted : 23 November 2013 16:11:07
an easy one full name of the man called the red baron,the famous type of aircraft he flu, and the name of the pilot reported to have shot him down benny.BigGrin
benny b
#483 Posted : 03 December 2013 20:22:58
will try another one if to hard give the common name given to the battle in the Ardennes. benny.LOL
#484 Posted : 03 December 2013 23:46:52
Hi Benny
Manfred Albrecht Freiherr von Richthoven, Fokker DR1 (a copy of a captured Sopwith Triplane) and Capt. Arthur 'Roy' Brown (although current speculation suggestshe was actually shot down by an Australian AA machinegunner from the ground!
Battle of the Bulge?
Sorry, been a bit busy lately! BigGrin
benny b
#485 Posted : 04 December 2013 19:23:35
hi that is correct on both questions so over to you robin. benny
#486 Posted : 04 December 2013 20:27:38
Thanks Benny!
OK then, Royal Navy Guns.
Out of the 32lb Long Gun and the 68lb Carronade, which required the fewer number of crew?
And which had the higher rate of fire and why?
Best of luck
#487 Posted : 04 December 2013 23:44:58
Plymouth57 wrote:
Thanks Benny!
Best of luck
Ok total guess i am going for carronade as having fewer crew and had the higher rate of fire because it took longer to recoil and load the long gun Confused Confused Confused ??
#488 Posted : 05 December 2013 21:22:53
Right on both counts Jase!
The carronade was quicker as you say because of the shorter barrel and also because of the design of the carriage. The carronade could only recoil back along the slider groove and could simply be pushed aound its front pivot to aim. The long guns could easily swerve sideways when they recoiled which required extra crew to manhandle them back in line with big wooden 'crowbars'.
Well done and over to you.
#489 Posted : 06 December 2013 13:44:38
right then
During the English Civil War the Parliamentarians held London. In which city did the Royalists establish their rival capital?
benny b
#490 Posted : 06 December 2013 19:35:43
hi jase he moved it round over the years but are you thinking oxford. benny.
#491 Posted : 06 December 2013 20:47:44
Yes i am
well done over to you
benny b
#492 Posted : 08 December 2013 19:00:38
easy one name the planes used on the dolittle raid and were they took of from. benny.
benny b
#493 Posted : 13 December 2013 16:46:47
the questions can,t be to hard. benny.
#494 Posted : 13 December 2013 23:25:51
BigGrin B25 and the aircraft carrier hornetCool
benny b
#495 Posted : 14 December 2013 15:27:56
correct over to you. benny.
#496 Posted : 14 December 2013 16:50:36
BigGrin Where is the expression ' Cock Up' from and whyCool
#497 Posted : 30 December 2013 10:13:16
Best answer this then .
When an arrow shaft was fletched one of the flight feathers used was a cock feather the other two were not.
So when firing the arrow from a bow the cock feather should be the top most vertical this ensures a straight and true flight to the target but if the arrow was loaded with out checking properly or in a panic it could fly to the left or right so this lead to the saying 'its a cock up' shortened to 'cock up'.
And that's the answer
#498 Posted : 30 December 2013 10:15:04
BigGrin ok an easy one what was the name of the 1st British tankCool
benny b
#499 Posted : 03 January 2014 20:13:24
is it the mark 1 first used on the somme. benny.
#500 Posted : 03 January 2014 20:45:10
BigGrin sorry Benny perhaps i should be more specific and say it was the 1st test tank show to the british militaryCool
Guest (6)
This page was generated in 0.193 seconds.
