162 Pages «<108109110111112>»
NMBROOK
#2181 Posted : 15 December 2013 05:45:57
Hi Alan,thought I would pop in and see how she is progressingBigGrin
Fabulous work,she is looking greatCool Cool Cool Just a suggestion,you can always try supergluing some sandpaper to a slightly smaller dowel for cleaning your holes out,you don't have to use a stroking action then which can cause more breakout at the rear of the hole,just twist.
Kind Regards Nigel
#2182 Posted : 15 December 2013 09:10:41
Kind Regards Nigel
Thanks Nigel for dropping by and appreciate your comments. Your suggestion sounds like a better way forward and will give it try on the next set of gun ports....Cool Cool .. Nice to hear from you again and hope everything is going well for you....Cool
Kind regards
#2183 Posted : 15 December 2013 10:19:15
Hi Alan, BigGrin
Looking good as always. Cool
The latest gun ports look fine,
Yipee more gilding LOL
#2184 Posted : 15 December 2013 12:40:44
Looking good Alan, the holes turned out very well and I can imagine this was difficult to do as well.
I actually went back to your index and found page 89 to see if there was anything that could have been pre - drilled but really there isntAngry
For myself (if this is my next build) I may possibly plank the verticals onto thick card pinned to the bulkhead so the planks sandwich the card between, the planks are glued to the card but the assembly is pinned to the bulkhead and when dry, can be removed for drilling on the bench. I have used the card method on the vic for the forward bulkhead to be able to add all the detail etc but not be working on the actual model. This is just something I may do but not anything I would recommend to others unless it actually works on the SOTSBigGrin
Coming on really well anyway, keep it up!
Foz
#2185 Posted : 15 December 2013 13:46:22
Looking really fine Alan. Great work on those gun ports they look fine.
Foz ThumpUp
#2186 Posted : 15 December 2013 22:25:23
delboy271155 wrote:
Hi Alan, BigGrin
Thanks Derek, its not a worrying as it was now that I have some of them done.. Thanks for looking in and commenting....Cool Cool
Regrds
#2187 Posted : 15 December 2013 22:28:22
Thanks Stevie, appreciate you looking in and for you kind comments.... Like you idea of thick card and I too looked whether there was anything that could have been pre-drilled with no luck.... Cool Cool .. Think you would have to watch how thick the card was so as not to change the overall thickness of the bulkheads or the gun port ornamentation may not fit correctly....Cool Cool
Thanks again and regards
#2188 Posted : 15 December 2013 22:29:32
Foz ThumpUp
Thank you Foz, your comments are appreciated.... Cool Cool
#2189 Posted : 15 December 2013 22:34:29
Short update to show I have now refined the process and have completed 6 of the bulkhead gun ports.... Changed the process a little, rather than use a half round needle file I did as was suggested by Nigel. Glued some sandpaper onto a piece of 10mm dowel, drilled the hole as before and finished off using the dowel in a twisting fashion and not a back and forth fashion... this resulted in far less damage on the inner wall... Cool Cool .. This method was a lot smoother, faster and gave much better results with very little need for modellers putty....Cool Cool .. Thanks Nigel, great tip.... Cool Cool
Happy building all...
KobusBeukes
#2190 Posted : 16 December 2013 06:53:21
Hi Alan
The results speak for themselves! Well done and keep the stunning work up!
Kobus
Current Build
#2191 Posted : 16 December 2013 10:35:54
BigGrin Lovely work Alan and a bril tip from Nigel
Happy building rgd Martyn
#2192 Posted : 16 December 2013 22:55:49
KobusBeukes wrote:
Hi Alan
Thanks for the very kind words Kobus, thanks for looking in....Cool Cool
#2193 Posted : 16 December 2013 22:56:50
Thanks Martyn, hope the tips helps others.....Cool Cool
#2194 Posted : 18 December 2013 13:42:06
Ports look great Alan
J
#2195 Posted : 18 December 2013 21:03:41
J
Thanks Jase....Cool Cool
#2196 Posted : 21 December 2013 22:40:59
Next update, have now completed the railings on the quarterdeck.. no real problems except a little fiddly in places.... Had to carefully widen the holes for uprights as it really was a tight fit and was concerned I would snap the top frames, used a fine square file for this task... Only thing left to do now on issue 67 is to drill the two gunport holes on the forecastle bulkhead and fit the décor, then I can move onto issue 68 which is the half way point of the build... Cool Cool
#2197 Posted : 21 December 2013 22:48:41
Hi Alan,BigGrin
As always, BRILLLL Drool Drool
Keep it coming.
#2198 Posted : 21 December 2013 23:09:44
BigGrin Hi Alan
nice job, as with all thin precuts a little fettling and adjustments are needed at times but you have done a fine job
#2199 Posted : 21 December 2013 23:44:47
delboy271155 wrote:
Hi Alan,BigGrin
Keep it coming.
Thanks Derek, your very kind comments are very much appreciated....Cool Cool
#2200 Posted : 21 December 2013 23:45:51
BigGrin Hi Alan
Hi Andy, appreciate you looking in and for your kind comments....
Guest (10)
This page was generated in 6.339 seconds.
