12 Pages «<89101112>
sparks
#181 Posted : 12 December 2013 20:39:06
Thanks Steve,
hope to be back with it soon.
sparks
#182 Posted : 19 December 2013 00:18:05
Hi all,
After regaining the use of a full compliment of digits, I set about completing the launch. The last main item to build was the rudder, but I immediately had an oops moment. Upon looking at the rudder details I noticed that the ships boats do not have a prominent stern post like the mother ship, or indeed, the donor hulls I'm using, so that had to be shaved off.
To get the rudder tight against the stern board, cut outs are formed in the top section of the rudder and on the back of the keel to fit the pintles into, unlike Victory, where all the pintles are on the rudder,and all gudgeons on the stern post.
I made the pintles and gudgeons from various pieces of small brass and copper strips.
The rudder itself was cut from styrene sheet and again, the pintles and gudgeons made from strips of brass and copper.
Finally, a length of 0.5mm brass micro tubing was drilled and glued into the top front edge to form the steering arm.
A couple of coats of paint, and the stern board repainted, to complete the working rudder.
A couple of shots of the completed launch in position on the skid beams.
Its good to be back on the build. BigGrin
sparks
#183 Posted : 19 December 2013 01:43:32
Something else I was tinkering with before the finger incident Blushing
The boats oars.
Just made one to get a feel for how I would do them.
I used a length of 0.8mm brass micro tubing and flattened one end with pliers hoping to get the look I wanted for the blade of the oar, but it didn't look wide enough. So I glued a piece of 0.5 X 1.5 styrene strip to each side of the flattened end, then filed them down to get the thinner profile required. I then inserted a small length of 0.5mm brass tubing into the other end to form the hand grip.
Finished off with a couple of coats of matt white paint.
Another little mini project to fall back on. If I decide to make the full compliment of oars for all the ships boats, there's 66 to do Blink of varying lengths.
More on the main build soon. If I can keep myself uninjured at work BigGrin
Foz
#184 Posted : 19 December 2013 10:54:01
Very nice work on the launch, love he detail you have added. Keep up the great work.
Foz ThumpUp ThumpUp
#185 Posted : 19 December 2013 16:16:29
Hi Alan.
great work on your launch. it looks realy nice when sitting on your victory. Look forward to seeing your progress ian Cool Cool BigGrin
sparks
#186 Posted : 20 December 2013 21:52:37
Cheers Foz and Ian for your comments.
#187 Posted : 20 December 2013 22:35:46
Beautiful work on that launch Alan, especially loved the oar too, not the easiest of things to make. And Ian was right, it does look great on the skids!Cool Cool
Well done!
#188 Posted : 20 December 2013 23:40:31
Great work Alan, looks superb....Cool Cool
sparks
#189 Posted : 24 December 2013 20:58:55
Thanks Robin and Alan for your comments, much appreciated.
I have made a start tinkering with referbing the gun ports and lids with the new PE gear, but I doubt much will be done over the festive period BigGrin
Which brings me to my reason for logging on.
A MERRY CHRISTMAS TO EVERYONE
sparks
#190 Posted : 31 December 2013 22:21:52
HAPPY NEW YEAR TO EVERYONE
#191 Posted : 02 January 2014 12:05:19
Good job there Alan, well done, looking forward to your next instalment.
sparks
#192 Posted : 03 January 2014 22:04:37
Thanks for your comments Hans, much appreciated.
sparks
#193 Posted : 22 January 2014 22:12:26
Hi all,
I'm still plodding along with the gun port refurbishment, but haven't done a great deal since Christmas as I've been busy with work and family,
it's a pain how these things get in the way of your hobbies BigGrin
Here's a few pics showing the refurb procedure.
Step one is to grind off the hinge and large raised detail around the holes on the gun port lids.
The new PE hinges are then fixed to what was the inside face of the lid.
Followed by the eyelets.
The old riggols are carefully removed and replaced with the new correct profile PE ones.
The colours on the lid are reversed, eyelets fitted to what is now the inside of the lid, new riggol painted in, gun fitted, lid fixed in place and lanyards attached.
Only quite a lot more to do BigGrin
sparks
#194 Posted : 22 January 2014 22:38:27
Hi all,
Just a quick post regarding another little enhancement.
Through another forum, I found a guy in the US who does miniature engraving. After a couple of emails back and forth, he came up with this.
Notice the little plate on the quarter deck.
Move in closer and see what it is....
I had him make it as small as he could (7mm X 4mm) for me. It cannot be read with the naked eye, (well at least I can't read it), buts that's what I wanted, but he can obviously make them bigger, and you guys doing the De Agg model could have it bigger without it looking too over scale. It does make an interesting and authentic addition to the model.
I'm not involved with this guy in any way and am not looking to make anything from it. He charged me $20 plus postage. If anyone is interested, PM me and I will pass on his contact info.
#195 Posted : 22 January 2014 23:25:06
Hey I like that! I'm hoping to scratch build a living Nelson eventually, (possibly two, one standing and one laying wounded) but I suppose I could have his secretary standing behind him holding the plaque!LOL
That's a great idea though, well done!
dtssyst
#196 Posted : 23 January 2014 02:56:49
The plaque is a very nice touch. Can't wait to see more.
sparks
#197 Posted : 24 January 2014 22:14:30
Thanks for commenting, much appreciated.
sparks
#198 Posted : 24 January 2014 22:31:24
Thanks Robin,
I am also making a Nelson figure by converting one of the Minifig officers. Poses a problem of what to place on the quarter deck, the plaque or Lord Nelson (plaque is only temporary at the moment).
Mind you, if the plaque had been there on the 21st Oct 1805 it may have convinced him to change into a lower ranking uniform, then who knows how things would have ended up. Definitely still a great victory for Nelson,
but he may have returned triumphant, probably married Lady Hamilton,
had more children, caused more scandal, died an old man, still a great hero, but I doubt there would be a Nelson's column in Trafalgar Square,
would there even be a Trafalgar Square ? Sorry, I'm rambling again BigGrin
#199 Posted : 24 January 2014 23:24:00
Love the little plaque Alan, really nice idea.
He probably would have tripped over it just as the sniper fired his shotLOL Could have been a lifesaver - but then it would have said "Here Nelson Tripped and Fell"LOL
#200 Posted : 05 February 2014 14:59:28
Hi Alan.
Superp little touch with your here nelson fell plaque.
Your gun port lids also look great. look forward to seeing more. Ian Cool BigGrin
Guest (10)
This page was generated in 0.235 seconds.
