Nice work Andy, look forward to seeing your decking in place.... Regards Alan
 Hi Alan Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Some more progress with the hull . The painting of the hull is now finished using Tamiya's Hull Red and good old Kure Grey. After the paint was dry I added the wood deck components to the hull sill some fittings to be added but gives a good impression of the finished item. regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Lovely work Andy, that decking really adds to her character....  Regards Alan
Very nice Andy, really looks good with the deck in place. Steve
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Great work Andy, the wooden decks really look good. Look forward to your progress. Regards Foz
 Hi Alan ,Steve and Foz Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 28/04/2013 Posts: 158 Points: 486 Location: England Cheshire
Hi Andy, Looking very good so far, keep up the good work.
Regards, Tony.
 Hi Tony Thanks for your comments and looking in Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Progress has been slow as iv been making up ,painting and adding decals to the three Sierans that were stored in the sub hangar and also the bonus Sieran on a display stand with torpedo's that is part of the special edition set. Small and fiddly work here , the decals took me a day to apply and the canopy decals just wouldn't have fitted but for the use of good old micro set/sol but im relatively happy with the results. regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All The three Sieran's have now been mounted to the deck plate and the placed into the hangar tube and the main bridge components put together there is still a load of etch to be added in this area. The lower masks to drill holes for the railings have been cut out and stuck down on the main hull to enable the drilling of these holes. More soon Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Brilliant work Andy! Absolutely love it, looks very fiddly though. Can't wait to see more of this one Steve
 Hi steve Thanks for looking in, fiddley yes with lots more miniscule etch to go on regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Very nice Andy. The detail is fantastic. Look forward to your progress. Regards Foz
Another really nice piece of work from you Andy, attention to detail is incredible.... very well done.... Regards Alan
 Hi Foz Thanks for looking in and your comments as always there apreciated regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Alan still a good deal of detail to add yet , thankd for looking in regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy. Looking very nice. Look forward to seeimg your progress. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Hi Ian Thanks for looking in and your comments Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Some more progress ,The upper wood decks were added and the mask's used to drill the holes. the guns were then added to the bridge/hangar area after fixing in place. Then its a case of adding the etch some of which is seriously tiny working from the centre of the model and adding to guns and fittings around the bridge .All the upper railings and ladders are now finished just some hand irons to fit in parts then its the rest of the railings to go on. More soon Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (6)
