Plans for HMS Victory scratch build Options
Brian100
#1 Posted : 01 January 2014 10:38:38
Rank: Beginner Level 3
Advice required on who supplies the best plans for a scratch build of HMS Victory.
Thank Brian
#2 Posted : 01 January 2014 11:33:01
The most accurate representation is the the 1/72 kit from Jotika/Caldercraft.
You can downoad the manual, but unsure if they sell the plan set..
http://www.jotika-ltd.co...24768/Manuals_Front.htm
Brian100
#3 Posted : 07 January 2014 11:14:49
Thanks Tomick, I have downloaded the manual. I have been checking the modelling sites but there doesn't appear to be any plans for the caldercraft model. I noted that there are drawings in the parts section of the manual but they don't appear to be to scale.
Brian
#4 Posted : 07 January 2014 14:48:18
Might be worthwhile asking them direct, or keep an eye out on such as eBay for anyone disposing of the plan set after having completed the build.
Brian100
#5 Posted : 07 January 2014 20:26:38
Thanks for the advice Tomick.
Brian
moriarty
#6 Posted : 24 January 2014 13:00:11
Hi there Brian, depending what scale you are going to finally build in I have a few spare parts from a victory build I aquired. No hull but i do have stern boards and figure heads and a few other pieces.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
Marcel
#7 Posted : 29 January 2014 18:09:03
I am also interested in a scratch build, but the availability of the correct size cannons is a constant issue when constructing a scale model.
Sovereign of the Seas
This page was generated in 0.080 seconds.
