8 Pages «<34567>»
ARPurchase's build diary of the Samurai Armour Options
dandare
#81 Posted : 01 January 2014 11:02:02
Looking Fantastic Andy
Dan
#82 Posted : 01 January 2014 11:19:11
BigGrin Hi Dan
longblade
#83 Posted : 01 January 2014 12:25:41
Looking good squire, I agree with you on the chain mail, I found a lot of loose links, soon put right. putting mail to sleeve is a bit fiddly, just need to persevere.. Bob.
#84 Posted : 01 January 2014 13:50:29
BigGrin Hi Bob
Thanks for looking in and your comments I also had some chipping of paint but soon fixed
#85 Posted : 01 January 2014 16:31:24
All the Tassets are now fitted to the Chest plates still needs a good polish and so its onwards with the sleeves
#86 Posted : 01 January 2014 18:38:25
Hi Andy, the more I see of this the more I love it... Love .. Think you are producing something special here.... Can't wait to see it with the chainmail attached... Cool Cool
#87 Posted : 01 January 2014 23:15:33
BigGrin ThanksCool
#88 Posted : 01 January 2014 23:22:21
The chain plates have now been sewn onto the silk arm backing starting with the shoulder plate then the hand guards I made a change here with the sewing of the plates as I went round as instructed but then followed it back round so both sides were fixed in place thus a stronger bind.
Then all was left was the sewing on of the chain mail to the silk following the set patern, again I changed the way the instructions advised and used long dress makers pins instead of masking tape, this concludes issue 8
#89 Posted : 02 January 2014 09:07:55
Lovely work Andy.... Cool
#90 Posted : 02 January 2014 13:08:17
BigGrin Hi Alan
thanks for your comments
#91 Posted : 02 January 2014 20:35:50
#92 Posted : 03 January 2014 11:04:50
BigGrin Hi Steve
As for the swords probably not I feel with or without then it wont detract from the overall finish as its a lot larger and imposing as it stands.
#93 Posted : 18 January 2014 21:09:50
Continuing to finish off the left sleeve firstly by adding the retaining straps to the outer wrist area and then adding the toggles and ties. The backing was then trimmed to the correct shape and the yellow swead trim attached to it except for the shoulder are as more attachments are to be made here.Still more to be added here so more soon
#94 Posted : 19 January 2014 17:08:40
Couple of pics on progress, the swead hand area has now been added
#95 Posted : 25 January 2014 17:54:02
The left arm is now finished and mounted as is the 4layers of thigh armour. more soon
#96 Posted : 25 January 2014 18:32:54
Coming together nicely Andy.... Cool
#97 Posted : 25 January 2014 19:06:29
BigGrin Hi Alan
#98 Posted : 16 February 2014 20:31:59
I have made up the second chainmail and plates for the right arm, now to start on the leg guard plates
more soon
#99 Posted : 16 February 2014 23:28:10
Hi Andy,
Just a fantastic job your doing on this armour, I tell you this kit is so close to the real thing, I was at the V/A museum London this week and I had a very close look at Samurai-Armour your work is so close Andy you must be very proud of your work keep sending.
Regards.
Trev.
#100 Posted : 16 February 2014 23:40:10
BigGrin Hi Trev
Thank you for you kind wordsBlushing . Its a different form of modelling and the lacing can be a right pain but at the same time quite theraputic .One of the reasons I took this on was its closeness to the real thing and your comments have proved my theory correct. Again thank you for your comments, there,s still more to come like the greaves yet
8 Pages «<34567>»
This page was generated in 0.264 seconds.
