162 Pages «<111112113114115>»
#2241 Posted : 02 January 2014 22:31:38
Plymouth57 wrote:
Hi there Alan!
Looking great! They sure kept their seamen lean to get down the hatches in those days!!BigGrin
Just a quick query, when you say
"Marked on the upper edge of the masking tape the mid point between each gun port ready for drilling and the attaching of the eyelets and rings", what are the eyelets and rings for? And when you say 'mid point' do you mean the exact centre of the actual gun port or the mid point between two gunports?
On the Vic there is an eyebolt set back on the deck from each gunport (on its centre line)for the running in/out tackle but nothing 'mid point' between the ports.
I think I'm just getting confused between mid points and betweens but I thought I'd check just in case!Blushing
She's really going to be a beautiful Lady when she's 'fully clothed' and a great credit too!
Happy New Year!
LOL LOL LOL Robin, only hired the lean and mean for this fighting machine.....LOL LOL ..
At least I know the difference between my betweens and midpoints...LOL LOL Flapper LOL . To clarify, the top edge of the masking tape runs along a line from the centre of one port to the centre of the next and so on..... Marked on the top edge of the masking tape the midway points between gunports, that's where the holes will be drilled for the rings... Cool Cool .. Been looking at Sephtons book and I cannot find any explanations for what the rings were actually used for. Some of the photos contained in the book had these rings whilst others didn't so I really cannot answer your question... Maybe there are others in the forum with far more nautical knowledge than I who can hopefully shed some light as to their possible use.... Blushing Blushing Blushing..
Thanks again for the kind words and a happy new year to you too.....
#2242 Posted : 02 January 2014 22:32:41
stevie_o wrote:
Quality work Alan, looking amazingBigGrin
Thanks for the kind comments Stevie and thanks for looking in.... appreciate your support.... Cool Cool
#2243 Posted : 02 January 2014 22:41:23
Continued today with shaping and fitting of the forecastle hatchway and glued into position.... While waiting for it to set I moved onto making up the hatchway steps... Fitted the hatchway surrounds followed by the steps themselves... Was a little concerned I could inadvertently let the steps fall into the hatch which would be difficult to recover. To avoid the problem I threaded a piece of fishing line between the steps and found this aided the fitting...Cool Cool
Moved onto drilling the .5mm holes between the gunports on the upper edge of the masking tape. Took the rings and threaded them onto a length of fishing line, dipped the rings into ammonia to remove any possible contamination, rinsed them off and dried before dipping them into some krick solution to blacken. Did the same with the eyelets.... Cool Cool .. Made up the rings by attaching a ring to eyelet and finally with a drop of CA attached to the hull. All rings now fitted... That brought issue 70 to a close and the build will now go on hold until the release of the next issue on Wed, that's when I move onto fitting the rudder I believe...Cool Cool .. Will now spend some time working on the Titanic..... Cool Cool
Happy building all.....
#2244 Posted : 03 January 2014 18:00:43
Hi Alan.
As I thought, I did have completely the wrong end of the stick! Your last set of photos explained it all! Blushing
I had visions of you drilling the holes for those ring bolts midway between the gunports on the deck not on the hull! That's why I was worried as I couldn't see any point to having them there!
Mind you, I still can't see any point to having them on the hull in that position either!Blink
Only explanation I can come up with is that they expected her to capture so many enemy ships that they put in dozens of towing hitches to bring them home with!!!BigGrin BigGrin BigGrin Laugh Laugh Laugh
I must admit though it does set the hull off really nicely! Cool
Keep them coming!
#2245 Posted : 03 January 2014 19:08:52
Hi Alan, BigGrin
Some more good work there.Drool
A very handy tip for installing the ladder as well. Cool
#2246 Posted : 03 January 2014 22:26:56
Plymouth57 wrote:
Hi Alan.
Keep them coming!
Thanks Robin, pleased its all clear now and apologies if I caused you any confusion.....Laugh Laugh .. I too think the rings set the hull off nicely....
#2247 Posted : 03 January 2014 22:28:20
delboy271155 wrote:
Hi Alan, BigGrin
Thanks for looking in and commenting Derek, hope you find the tip useful...., it made the task a lot easier.....Cool Cool Cool
#2248 Posted : 04 January 2014 15:36:37
BigGrin lovely work Alan . Looking good by the way where did you get the Krik black stuff from . Thanks Martyn
#2249 Posted : 04 January 2014 19:14:37
Thanks Martyn, got mine on Ebay, have supplied the link...
http://www.ebay.co.uk/it...8a688789f#ht_1060wt_721
#2250 Posted : 04 January 2014 22:25:53
#2251 Posted : 04 January 2014 23:26:41
stevie_o wrote:
This is getting boring now Alan, I can't think of anything else to say except !!!Fantastic!!! I absolutely love this buildBigGrin BigGrin BigGrin
I'm going to keep saying it thoughLOL
Thanks for the wonderful comment Stevie, so appreciated.....Cool Cool .. I'm loving the way its looking right now, have to say though the Titanic is proving to be a little more challenging being in a much smaller scale....Blink Blink Blink
Thanks again,,
#2252 Posted : 05 January 2014 09:08:37
BigGrin Thanks Alan for the info ordering as we speak ThumpUp Rgd Martyn
#2253 Posted : 09 January 2014 23:19:51
Started work on issue 71 which is the making up and fitting of the rudder... Cleaned off all the black ash, planked the rudder with walnut strip and the upper 46mm with sapelle, that including the edging.... Cool Cool .. Tomorrow will give it all a fine sanding and will start the process of applying coats of varnish to match the hull.... Will also make a start on making the gudgeons and pintels including blackening.....Cool Cool
#2254 Posted : 13 January 2014 22:15:26
Issued 71 complete...Cool Cool
der Gohfelder
#2255 Posted : 13 January 2014 22:32:54
Hi Alan!
Very nice! I like your fantastic detail work more and more! ThumpUp
Regards, Bernd
#2256 Posted : 13 January 2014 23:57:49
der Gohfelder wrote:
Hi Alan!
Regards, Bernd
Thanks Bernd, appreciate you looking in and your comments as always.....Cool Cool
hudsonrobert49
#2257 Posted : 14 January 2014 07:41:21
Hi Alan. I really Like your fantastic work Drool Drool Drool
Rob
Bridlington.
KobusBeukes
#2258 Posted : 14 January 2014 11:31:24
Hi Alan
Looking great as always. A job well done!Love
Kobus
Current Build
#2259 Posted : 14 January 2014 12:48:01
Alan, it really looks the business!! TOP JOB
Kind regards
Mike
#2260 Posted : 14 January 2014 19:36:54
Thanks for the very kind words Rob, appreciated... Cool Cool .. So pleased to see you back on the Suprise build as it was one of my favourites on this site... will be following your progress..... Cool Cool
Guest (10)
This page was generated in 0.216 seconds.
