6 Pages <12345>»
ARP's Zero Options
#41 Posted : 03 January 2014 23:00:35
More progress made.
The distributor ring has been added to the front and the oil pipes added to the rear ring of cylinders the front rocker boxes and valve stem covers will be added in one go like I did the rear set. Some chipping has occured around the engine but it looks quite realistic to my eye.
The second wing is well on the way to construction im not painting this one as it will be skinned.
The front fuselage is now being put together, the two halves joined and the various formers added as instructed, also the machine gun fired shells chute has been fixed after the machine guns had been added. Lastly the lower rear fuselage cover has been glued in place.
This concludes pack 6
Warthog
#42 Posted : 04 January 2014 18:13:25
Looking good Andy and the chipping does add to the realism BigGrin
#43 Posted : 04 January 2014 20:59:36
BigGrin Hi Spencer
Thanks for your comments much appreciated
#44 Posted : 04 January 2014 21:03:57
Small update on pack 7, I have added the flap and aileron bulkheads to the wing. I also made up the metal parts some of which benefited from some filler
more soon
#45 Posted : 04 January 2014 21:38:12
Didn't realise you were building this one Andy....Blushing Blushing .. Another great piece of work, looking good.... Cool Cool
#46 Posted : 05 January 2014 02:02:19
BigGrin Hi Alan
Its unlike you to miss anythingBlink thanks for looking in and your comments
#47 Posted : 05 January 2014 10:58:57
BigGrin Hi Alan
LOL LOL .. Especially your builds....Blink Blink .. As I think the quality of your work is superb and members can learn so much from you..... Cool Cool ..
#48 Posted : 05 January 2014 19:42:47
BigGrin Hi Alan
thanks for the kind words
#49 Posted : 05 January 2014 20:01:20
I have finished mounting the gas bottles , oil tank and various bars to the forward fuselage.
The fuel tank was then made up and painted with aotake , one word of advice here the tanks are made of very thin aluminium and will not stand much in the way of tidying up with files ect so when glueing together the maximum in accuracy when lining the two sides up saves a lot of fettling with a delicate piece of metal later.
Finally the instrument panel was painted up and the dials and lenses added. the painting is a little tricky in parts due to size and small gaps.
Another change I made here was to the central dial , the printed dial was ready to be used but below it is a yellow strip which is also part of the instrument but this is not pre cut, I cut this piece out and added it to the panel. If you look at the picks a red arrow and circle will tell all.
Lastly on the clear plastic parts that are left over for future use the reflector sight [ circled red] was broken so I have ordered a replacement. This concludes pack 7.
#50 Posted : 26 January 2014 22:14:22
The three lights have been added to the wing as has the fuel tank the light to the instrament panel has also been added.
All the rocker boxes have now been added as have the push rod tubes
Still more to come
#51 Posted : 27 January 2014 08:22:25
Hi Andy,
you are going from strength to strength with this model it is not only look the part but skilfully built watching with interest.
Trev.
#52 Posted : 27 January 2014 08:54:20
Looks fab Andy
J
#53 Posted : 27 January 2014 20:00:38
BigGrin Hi Trev
thanks as always for your comments and observations ,always appreciated
#54 Posted : 27 January 2014 20:02:39
BigGrin Hi Jase
#55 Posted : 27 January 2014 23:40:48
#56 Posted : 28 January 2014 21:29:26
BigGrin Hi Steve
#57 Posted : 01 February 2014 16:48:33
some more progress,
The oil pipes have now been added to the second set of cylinders.
More ribs made up with there bracing struts.
The instrument panel has been fixed in position as have the fuel/air mixture lever, pitch control lever and the undercarriage lever.
I am still painting the bits for the undercarriage oleo legs but will update as this is finished
#58 Posted : 01 February 2014 20:21:12
Finished making up the oleo leg and fitted the mounting/pivot block to the wing lastly the wing machine gun was mounted in position in the wing. This concludes pack 8 so more next month.
dandare
#59 Posted : 01 February 2014 23:42:55
coming together nicely Andy
#60 Posted : 01 February 2014 23:47:54
BigGrin Hi Dan
6 Pages <12345>»
This page was generated in 0.500 seconds.
