Scroll Saw Options
GilShapley
#1 Posted : 08 January 2014 16:49:26
Anyone recommend a good scroll saw
I have been trawling the net which has only added to my confusion
Some have lights, blowers. One has a flexidrive attached
The blades seem to vary either with or without pins
variable speed is another option
Dont need to spend a fortune, something basic to start
Confused Confused Confused Confused Confused Confused Confused Confused Confused Confused Confused Confused
Current Build:-
#2 Posted : 08 January 2014 17:22:34
As ever with tools, what you get for your money and quality are generally reflected in the price.
If you don't want to spend a lot, then you need to decide what you can live without. This link gives a few pointers..
http://www.airfieldmodel...g_tools/scroll_saws.htm
experten
#3 Posted : 08 January 2014 17:59:29
Groups: Registered, Official Builds
A lot of what you plan to do with a scroll saw should drive your purchase. If you are going to get serious with it, avoid things like the Dremel, or really anything with a pinned blade. A pinless blade will allow a much higher tension, which decreases blade drift. Also pinned blades are VERY limited in terms of width, as there needs to be enough meat in the blade to hold the pin.
The best saw out there, for the most reasonable price is the DeWalt. It was designed by a company called Excalibur, who makes VERY high end scroll saws. The Dewalt runs smoothly enough that you can place a coin on edge, turn the saw on, and the coin will not fall over. It has a good throat at 24", and the table is large enough to support a good sized project. The table also tilts both ways. There is a built in dust blower, which is a very nice feature. A light is available as an accessory.
HTH!
Mark (who works in a woodworking tool retail store)
Tired, Old, and Cranky!
This page was generated in 0.674 seconds.
