Use of Signatures Options
#1 Posted : 15 January 2014 12:37:08
It has been brought to our attention that the size of a number of Signature posts is posing problems for some readers.
These fill up the space at the end of your posts and can be used to tell people a little about you, your sense of humour, or what builds you are participating in or completed etc.
Problems arise when the signature gets too big which makes for longer pages and readers having to scroll further to get to each post, which is the prime focus of this forum.
If you have text in your signature, keep it to the height of 4-5 lines of ordinary unformatted forum text, a space line should be counted as a line.
If you have a large list, make it into a comma separated list which runs across the page, for example:
Building: Senna MP4/4, Hummer, D51, Spitfire
Finished: HMS Hood, HMS Victory, RB7
Under the bench: Mustang, San Francisco II
Or if you have an image, keep it to a sensible size.
Please try and follow these guidelines, as the Admin Team may Edit or Delete Sig's that are too big, or contain anything which should not be there.
Thanks.
#2 Posted : 06 July 2017 22:40:37
Can all members please take note of the above, some Sig's are becoming way too long.
Thanks
This page was generated in 0.100 seconds.
