32 Pages «<23456>»
tf64 Spitfire Build Options
#61 Posted : 20 January 2014 17:01:20
Hi Andy,try alshobbies.com
Regards trev
billbo
#62 Posted : 24 January 2014 13:51:11
great work there i missing part 4 and recived part 5 but as all the issues all broke so i have to wait anothr few weeks the wings look big could u but a picture up with something beside for size cheers billy
building the spitfire,RMS Titanic hachette and now starting the u-96 submarine
#63 Posted : 25 January 2014 19:13:08
Hi Billbo,
Thank you for your interest in my build,at present I'm waiting for part 6 this is the issue that will be in a box (no broken parts)I have just received a e-mail saying 14 days delivery, where is that posted?
As promised a photo you have asked for to show the size of the wing,I know that each build is a bit different but this is mine.
1st picture shows total length from end to end around 18in.
2nd picture shows Carbon Tube fitted with pull tags.
Hope this helps.
Trev.
Trev.
andysod
#64 Posted : 25 January 2014 21:05:38
Nice idea Trev with the pull tags, I take it they are plastic ties or look like it, Andy
#65 Posted : 25 January 2014 21:36:53
BigGrin Hi Trev
looking good there
#66 Posted : 25 January 2014 22:28:30
Hi Andy,
Thank you for replying ,yes they are plastic ties I found them very strong and easy to fit but not easy to cut ended up with a small hacksaw.
Trev
#67 Posted : 25 January 2014 22:37:47
Hi Andy,
Thanks for looking in value your comments
Trev.
billbo
#68 Posted : 26 January 2014 16:16:52
waw that a fair size i will start my wings when i have most parts to do as i dont want the wings to warp wile waiting for bit and i live far north of scotland next to john o groat a place called wick
#69 Posted : 26 January 2014 17:09:07
Hi Trev,Cool
Some nice progress there matey,BigGrin
My fuselage is in a clamped situation at the moment hoping it will be straight this time when it comes out.Confused
I have several issues to be getting on with now and was wondering where you got that great tubing from for inside the wings?
Happy building,
#70 Posted : 26 January 2014 19:30:49
Hi Billbo,
Good luck with the wings.
Trev.
#71 Posted : 26 January 2014 19:36:23
Hi Del,
Again thanks for looking in,tell you what that carbon tube is hard to cut had to use a fine hacksaw this is supplied in a meter length from.
www.alshobbies.com
Trev.
#72 Posted : 26 January 2014 19:47:15
tf64 wrote:
Hi Del,
www.alshobbies.com
Trev.
Cheers Trev,
Thanks for the link. Cool
#73 Posted : 26 January 2014 23:07:17
She's looking fab Trev and dare I say it big too.....Drool Drool .. Will keep following your progress..
#74 Posted : 27 January 2014 08:38:59
Hi Alan,
Good to hear from you your sovereign look's special very well built, as for the Spitfire yes it is big but a great kit to built, but I have a larger electric powered kit I made up some time ago, so this kit seems a bit small.
Trev.
#75 Posted : 28 January 2014 08:41:50
Looks great Trev,
This is a real model builders kit isn't it, really enjoying your build
#76 Posted : 29 January 2014 11:53:34
Jase,
Thanks for looking in, I find when you make the more fragile balsa builds you can break bits off which can cause a lot of frustration, I have just finished a Gloster Javelin (Balsa and tissue)point is this Spitfire build is a dream in comparison so as you say this is a builders kit.
Thanks
Trev
#77 Posted : 01 February 2014 20:10:56
Hi All,
Today I received part 6 of the Spitfire build, this turned up a very wet brown box due to the weather today but no broken parts.
The only point I was wondering about was that when I opened it there were only 3 parts in the box, has any one else had the same or should there be 4 parts ?
Trev.
#78 Posted : 01 February 2014 20:55:50
Hi Trev,BigGrin
Good to see the parts boxed, all be the box soggy Crying
At least they are in one piece,Cool
Would assume you should have four packs, but I`m not up to this stage so cannot confirm one way or the other.
One thing I have noticed though, the ribs still have the scrap inner bits in place. None of my ribs have had these bits still in place to date, so may be that stops the parts breaking as well.Confused
So with your itchy finger problem solved, it`s on with the next stage.
CAN`T WAIT.Cool
Having taken a closer look, you should have parts 24.
Looks like it`s a call to CS.Crying
#79 Posted : 01 February 2014 21:53:16
Del,
thank you for your reply,just checked with the Spit download online and all is present in the box just 21 to 23 this time.
So now I can build this part,I have some spare time away from the Victory build so I will post Sunday.
Trev.
#80 Posted : 01 February 2014 22:49:48
tf64 wrote:
Del,
Trev.
Hi Trev,BigGrin
That looks funny to me, as all advertising says four parts per delivery.
It may only be three this time, but I would check your bill to see how many parts you are being charged for.
32 Pages «<23456>»
This page was generated in 0.132 seconds.
