treenailing Options
val ellams
#1 Posted : 25 January 2014 17:25:11
Rank: Beginner Level 3
hi can someone eplain what treenailing is ,is it hard to do,what do you use to do it .cheers val
#2 Posted : 25 January 2014 17:38:29
Hi Val, treenailing is not difficult but is time consuming.... many ways to do it and the link below will show how I achieved it... Cool Cool
http://forum.model-space...sts&t=5013&p=49
Hope it helps..
#3 Posted : 25 January 2014 17:41:56
Hi Val
Treenailing is the depiction of the nails in the ends of each plank on the deck and hull. There are generally 2 nails at every plank end and adding these can enhance the overall look of the model.
The nails are usually made by drilling very small holes at each plank end, then inserting cocktail stick ends into these holes, the ends are left in and sanded down to deck or hull level. When the model is later stained the nails will be more pronounced. For a metal nail look soft brass wire can be used instead of cocktail sticks.
It is very repetitive work and will need thousands of nails for the entire model, also it can look overscale on a smaller scale ship.
There are a few builds on here showing this being done, I will post a link when I can find oneBigGrin
#4 Posted : 25 January 2014 17:43:38
Hope it helps..
LOL I was just looking for this page to put the link up, you beat me to it Alan
val ellams
#5 Posted : 25 January 2014 17:53:14
thanks to both of you for your reply,looks very time consuming but thinking of giving it ago as it adds great detail ,cocktail sticks on the shopping list BigGrin thanks val
#6 Posted : 25 January 2014 17:59:35
BigGrin Hi Val
Just something to be aware of the really cheap cocktail sticks are made from bamboo that can be a pain to cut, paying a little more gets you real wood ones
val ellams
#7 Posted : 25 January 2014 18:29:46
hi apurchase thanks for that tip will splash the cashBigGrin ,val
val ellams
#8 Posted : 25 January 2014 18:41:50
stevie 0 ,the soft brass wire what gauge would it need to be .val
#9 Posted : 25 January 2014 19:00:40
Hi Val,
0.5mm brass or copper wire will do. You need to drill the holes first then insert the wire, snip near the deck and sand off. The sanding will also slightly widen the nailhead.
#10 Posted : 25 January 2014 19:03:43
BigGrin Hi Van
or you can use brass pins from here just snip off the heads after
http://www.cornwallmodel...atalog/amati_nails.html
val ellams
#11 Posted : 25 January 2014 19:25:47
thanks for your replys, something to think about ,val
Marcel
#12 Posted : 25 January 2014 19:51:07
Treenailing works best on smaller than 1:45 scale to be correct. In a build like the Victory, the original ship has 120 ribs, while on regular bigger scales of model build , only has about 20 ribs. The nails on the bow are also bigger than of the rest of the build. The modeller need to decide if he want to be true to the original ship and keep the above in mind.
(I read this in some Issue between 25 - 35: Modellers Know How )
Marcel
Sovereign of the Seas
#13 Posted : 25 January 2014 19:54:29
Heres how the wire looks when done -
As and Andy said, pins can also be used but most pins will be too thick, 0.7mm - 1mm could look overscale, there is a 0.5mm very fine pin available too though. Another thing to think about is that if you are treenailing the entire hull then the pins will be expensive at at around £1.50 per 100 as you will need a couple of thousand of them.
val ellams
#14 Posted : 25 January 2014 21:25:10
thanks marcel for your comment it as certainly give me something to think about .val
val ellams
#15 Posted : 25 January 2014 21:26:45
it certainly looks good ,need to think this through ,thanks for the pic ,val.
#16 Posted : 26 January 2014 13:19:53
BigGrin Hi Val
Trenails were originaly wooden pegs but were superceaded by steal and other metals on more modern boats but the difference being that where metal was used either a wooden plug or tar was used to plug the hole thus sealing the metal in.
If you look at the pic below you can just make out the trenails/ plugs in the deck . hope this clears things up
val ellams
#17 Posted : 26 January 2014 15:30:49
thanks for the pic andy yes i can see what mean. thanks valBigGrin
This page was generated in 1.124 seconds.
