Plan Set Options
leggolon
#1 Posted : 25 January 2014 21:38:12
Hello
Can anyone tell me if a set of plans comes with the HMS Victory subscription kit?
Thanks
Larry
#2 Posted : 25 January 2014 22:26:36
leggolon
#3 Posted : 25 January 2014 22:33:29
Thanks Steve......
#4 Posted : 26 January 2014 00:04:52
Hi Larry,
The Instructions are organised in such a way as you don't need to rely on plans. Any lengths or diameters are given step by step. Plans are supplied with the masts as they are very busy and it helps get everything positioned correctly. You won't have a need for any other plans.
#5 Posted : 26 January 2014 00:14:02
BigGrin Hi Larry
Although full plans are not provided as such apart from the spar print outs they are really redundant as the monthly downloads give far more information than a set of plans would do at the stages you will be at.
Of course we modellers have the desire and idea's to improve and better our builds so I would also add that Jase has a set of pictures to down load from his trip to the Victory i will just add these are for personal use only during your build . Here's the link
http://forum.model-space...aspx?g=posts&t=1091
Hope this is of help
leggolon
#6 Posted : 26 January 2014 04:18:35
Thank you gentlemen for the information.
Larry
This page was generated in 0.308 seconds.
