New Modeller to this Site- D51 Locomotive Options
crbc54
#1 Posted : 30 January 2014 22:21:42
Hi All,I am new to DeAgostini and have no experience of part builds each month.Can anyone give me an opinion on this and D51 Locomotive in particular.I have been building various scale model Tamiya plastic kits recently with some success Do you think I would therefore be able to tackle this D51 build.How good are the instructions and do they explain how to paint or laquer the model.Any feedback would be great to help me take the plunge and go for it.Many Thanks,Clive
#2 Posted : 30 January 2014 22:38:40
Hello and welcome to the forum.
If you have experience of building plastic kits you will have no problem at all with the D51. The instructions are far superior to the average plastic kit instructions.
crbc54
#3 Posted : 30 January 2014 22:43:48
Dear Jase,Thank you for replying and this answer gives me more confidence to go ahead.Cheers,Clive
#4 Posted : 30 January 2014 22:49:30
BigGrin Hi Clive
Firstly welcome to the forum and below I hope I answer your query's.
Part works are designed so you can get a set amount of parts every month at a reasonable cost to yourself rather than having to spend the full amount in one go , so its a little kinder to the bank balance.
You have mentioned building several Tamiya plastic kits in the past and this will I think help you in your D51 build if you choose to take it on, you will get a monthly downloaded set of instructions for the parts provided which are very clear and concise and take the modeller through each and every stage for that issue.
There is a choice in the finish of painting or a laquer, I have chosen a painted finish but both options are clearly explained as the build continues.
I do think that you will enjoy this build but i am biased as im already building her. Hope this helps
P.S feel free to look at the official build which is in the brass laquer effect and mine which is in the painted guise
#5 Posted : 30 January 2014 23:03:49
Hi Clive and welcome to the forum... I started on this forum as a first time modeller and am now subscribing to a number of DeAg builds, they are all great kits and the instructions provided are excellent... Would have to concur with Jase and Andy, with the detailed instructions you get plus your experience with plastic kits should mean you will be able produce a really nice build..... Cool Cool Hope you enjoy your time with us....Cool Cool
#6 Posted : 30 January 2014 23:08:41
Welcome to ModelSpace Clive Cool
You've certainly no worries about having to contend with any soldering as its not needed.
Feel free to share your build with us as its always good to see another build underway.
#7 Posted : 30 January 2014 23:16:04
Hi Clive,
this is a wonderful kit and if you can tackle a Tamiya kit you have all the skills you need.You will find the same level of quality and fit as in the Tamiya kits.Even though it is mainly metal it is very easy to build so far.
Warthog
#8 Posted : 31 January 2014 00:03:37
Welcome to the forum Clive BigGrin
A great choice with the D51 and very popular here.. As has already been said there is a wealth of information on the forum regarding this partwork and you will have great a great time building it..
Spencer
crbc54
#9 Posted : 31 January 2014 13:04:06
Hi All,Many thanks to you all for replying.You have all definitely help me take the plunge and subscribe to the D51.All the kits I have built so far are Tamiya,Zvezda and Bell Kits.Everyone seems very positive about DeAgostini so well done to the Manufacturer.I now feel able to ask for help if I need it.Cheers,Clive
crbc54
#10 Posted : 31 January 2014 13:16:10
Dear All,forgot to ask about what tools are required to build the D51?
Many Thanks,Clive
#11 Posted : 31 January 2014 13:41:11
Just a basic selection of hand tools which you likely already have.
#12 Posted : 31 January 2014 23:34:13
BigGrin Hi Clive
all I use is a set of jewlers/watchmakers screwdrivers, medium thickness super glue ,epoxy glue and some thread lock solution but the super glue can also lock the nuts
crbc54
#13 Posted : 01 February 2014 14:53:48
OK Andy,Thats really helpful.I will take your advice,
Cheers,Clive
This page was generated in 0.217 seconds.
