will i need a build board for black pearl Options
steve-h
#1 Posted : 30 January 2014 22:54:10
Hi everyone
I was just wondering do I need to make a build board for the black pearl?
regards Steve
when I had an MRI scan all they found was an IOU instead of a brain
#2 Posted : 30 January 2014 22:58:37
Certainly recommended if you want to keep the keel on the straight and narrow
steve-h
#3 Posted : 30 January 2014 23:06:17
thank you for the quick reply what would you recommend Tomick ?
regards Steve
#4 Posted : 30 January 2014 23:14:23
Hi Steve, I wouldn't attempt to build these kits without a build board... I am using a white Conti board, 20mm thick for my Titanic build and the same thickness MDF for my SOTS....
Hope this helps...
#5 Posted : 30 January 2014 23:15:18
'L' brackets and perfectly flat base board at least 20mm thick, though you might want to wait until you have all of the keel and frames which will provide the frame spacing etc.
steve-h
#6 Posted : 30 January 2014 23:18:33
Hi and thank you Gandale and tomick for the advice, I will phone the bro in law he is a chippy so he will have some board about his placeBigGrin.
regards Steve
This page was generated in 0.033 seconds.
