Joined: 24/01/2014 Posts: 46 Points: 141 Location: gosport
Hi everyone I was just wondering do I need to make a build board for the black pearl? regards Steve when I had an MRI scan all they found was an IOU instead of a brain
Certainly recommended if you want to keep the keel on the straight and narrow
thank you for the quick reply what would you recommend Tomick ? regards Steve when I had an MRI scan all they found was an IOU instead of a brain
Hi Steve, I wouldn't attempt to build these kits without a build board... I am using a white Conti board, 20mm thick for my Titanic build and the same thickness MDF for my SOTS....
Hope this helps...
'L' brackets and perfectly flat base board at least 20mm thick, though you might want to wait until you have all of the keel and frames which will provide the frame spacing etc.
Hi and thank you Gandale and tomick for the advice, I will phone the bro in law he is a chippy so he will have some board about his place  . regards Steve when I had an MRI scan all they found was an IOU instead of a brain
