help please anyone gun port hole template Options
petew
#1 Posted : 11 February 2014 12:16:21
Rank: Newbie
hello i need help regarding the hole template in issue 43.it says to trace around the template and use to mark out the hole positions but it appears to be larger than the dimensions shown.should i use the template shown in the mag or should i make my own to the dimensions in the mag.
any help would be great as i dont want to drill a lot of holes in the wrong place.
#2 Posted : 11 February 2014 12:28:47
Hi Pete,
I noticed this also - the template is oversize, I made my own using the dimensions shown, ie 9mm wide, 6mm between the holes etc - don't trace the template patternBigGrin
#3 Posted : 11 February 2014 12:30:58
Hi there petew...I made my own using the specifications in the magazine...Hope this helps?
petew
#4 Posted : 11 February 2014 12:55:36
Rank: Newbie
Thanks for that I will make my own template.happy modelling
petew
#5 Posted : 11 February 2014 12:57:41
Rank: Newbie
Thanks for the help much appreciated
This page was generated in 0.350 seconds.
