12 Pages «<9101112>
sparks
#201 Posted : 13 February 2014 15:26:41
Thanks Steve and Ian for your comments,
much appreciated.
I'm still plodding along with the gun port lids, but not getting much done due to work etc, and another distraction, I bought myself a new keyboard,(musical instrument, not PC type BigGrin )
Was it just me, or was there problems getting into this site for a few days ?
#202 Posted : 13 February 2014 15:31:59
sparks
#203 Posted : 13 February 2014 22:34:57
stevie_o wrote:
Yes Alan, I wasn't able to get on the site all weekend - I didn't know what to do with myselfLOL
LOL Steve,
Those withdrawal symptoms are pretty bad aren't they BigGrin
karl josef
#204 Posted : 16 February 2014 19:10:34
fantastic work :-)how did you made ​​the small plaque, looks great.Cool
Best regards,
Reiner
sparks
#205 Posted : 17 February 2014 20:35:12
Thank you Reiner, much appreciated.
Through another forum, I found a guy in the US who does miniature engraving.
I had him make it as small as he could (7mm X 4mm) for me. It cannot be read with the naked eye, (well at least I can't read it), but that's what I wanted, but he can obviously make them bigger, and you guys doing the De Agg model could have it bigger without it looking too over scale. It does make an interesting and authentic addition to the model.
I'm not involved with this guy in any way and am not looking to make anything from it. He charged me $20 plus postage. If anyone is interested, PM me and I will pass on his contact info.
sparks
#206 Posted : 07 July 2014 19:07:49
Hi all,
Sorry to have been AWOL for so long, but have been really busy at work for the past few months, but hope to be back on the case soon.
#207 Posted : 07 July 2014 20:41:22
Welcome back Sparks!BigGrin
sparks
#208 Posted : 07 July 2014 21:27:00
Thanks Robin,
I see you have been busy on your Great War Diorama, looks fantastic mate,
I'd love to know how you find the time Confused
Great stuff
sparks
#209 Posted : 15 August 2014 22:50:11
Well, here we go with another small chapter in the massive saga that is upgrading the Del Prado Victory.
First of all, apologies for lack of action on this build over the last few months, mainly due to being very busy with work, and a couple of problems I will mention along the way.
I am still doing the refurbishment of the gun ports, and you may remember, back in post #194 the starting point was to grind off the bulky hinge and eyelet detail. So once I decided to start them in earnest with a production line so to speak, several of them shattered into small fragments just by gripping them (not too heavily) with pliers whilst trying to grind them, another testimony to the quality of the Del Prado mouldings ! So I had to search the internet for back issues containing gun port lids so I could decide whether to carry on with the ones I had or try to find aftermarket lids that would fit my ports (something I had tried in the past without much success!) Luckily I found a couple of sites and was able to get enough lids and spares to carry on. Below is the "assembly line" just for the port side, at the stage of fitting the front eyelets to the PE hinges.
The nice thing about the PE hinge set is that they have an additional feature for the lower gun deck port lids, a representation of the scuttle, which was a small oval shaped opening door to let air into the lower gun deck when the port lids were closed.
The port lids are then tuned over and another set of eyelets are fixed to what will be the inside face.
Painting them was not without its problems either, the bee lines on my Victory were painted several years ago and I couldn't remember what black I had used, I seem to remember using acrylic paints in tubes from my local art shop which is no longer with us. This was before the days of Admiralty paint sets and when they arrived I did re-do the yellow with Admiralty paints "Yellow Ochre" but left the black as it looked OK, its not glossy but has a slight sheen to it, some testing with Admiralty blacks showed "Dull Black" to be a reasonable match. Not wanting to drown out the detail on the hinges, I did two coats of watered down dull black and the result was unexpectedly, a rather shiny finish.
I then coated the lid, but not the hinges with Admiralty "Matt (Metal) Black")
this had the effect of not only dulling down the lid, making it a better match for the bee lines, but also made the hinge more prominent, a finish I was quite pleased with.
The inside face is painted with Admiralty "Red Ochre" and the eyelets picked out in Dull Black.
Next up, the rigols.
sparks
#210 Posted : 15 August 2014 23:08:37
The rigols were another cause for delay.
Like many things on this build the original ones were done several years back. Del Prado did not supply that sort of detail so through Model Dockyard I purchased a brass set for a 1/96 scale Victory, as nothing was available at 1/100 scale. I was pleased with them at the time even though they were slightly over size for my scale, and they have been fitted and painted in for years.
Fast forward to last year when I found the PE enhancements made for the 1/100 scale Heller (plastic) HMS Victory kit which included the gun port hinges I have used and the rigols. Had it been just the scale that was different I would have left my 1/96 scale ones where they were, but these are not only the correct size, but have the correct profile too.
Anyone who has stripped off their own previous work will know the feeling, needless to say, I was not too enthusiastic about starting, but they had to be changed.
Next up
The guns
#211 Posted : 15 August 2014 23:12:04
Welcome back again Sparks!!BigGrin
That's a lovely job you're doing on the lids! I know what you mean about the brittle DelPrado castings, I lost a couple of pins off the backs of the cannon barrels simply test fitting them into the holes in the gun port 'boxes'! Crying , you're upgrading is looking great, keep them coming!!
When I eventually get back to the old Victory my first post will be a dry-dock repair session! I thought she was nice and safe in the attic whilst I concentrated on the WW1 diorama (down the other end of the attic!). Unfortunately the thump I heard in the night a couple of weeks ago was a desk fan sliding off the top of a pile of boxes next to her. I'm sure that thing must be made in France! It landed right on her poop deck, breaking off the port barricade (now in two pieces!), demolishing the bucket barricade (well part of it anyway!) and even dislodging a couple of lids off the port stern too!Blink I'm just thankful it completely missed the skylight! If that had been ruined I really would have been a little miffed!BigGrin
At least all the damage is to scratch built parts - if I can do them once, I can do them again!!Flapper
Excuse me while I go and Cursing Cursing Cursing Crying Crying Crying Cursing Cursing Crying Crying Crying !!!!!
Good to see you back again!
#212 Posted : 15 August 2014 23:16:36
Lovely work Alan, great job on the port lids. Think they will look superb when fitted and will really enhance your build..... Following with a great deal of interest.....Cool Cool
sparks
#213 Posted : 15 August 2014 23:17:34
As mentioned earlier in the log, I wanted to represent the different size guns on the Victory. I had already got a good quality representation of the 12 pounders. The 24 and 32 proved difficult at this scale. I managed to find some but because of their larger muzzle size, they were too long, so I had to reduce the length by turning them in a drill while filing off the rear to just leave a fixing spigot.
The difference between the 12 and 24 pounders is very noticeable but between the 24 and 32 pounders its more subtle as you will see.
Next up
Putting it all together
sparks
#214 Posted : 15 August 2014 23:52:38
The guns were then glued into the receptacle holes in the rear of the gun port linings.
The finished gun port lids are glued into the gun ports in the open position using the original moulded hinge part, each one had to be filed down a little to make a tight fit.
Once the glue had set, the lanyards fitted earlier in the build were attached to the eyelets. On a test one I did, tying a knot didn,t look right as it was too large for scale, so I did it like this.
the lanyard is first threaded through the eyelet from front to rear.
Then, pulling it tight toward the front, some glue it dabbed on using a needle point.
When the glue is dry, the excess thread is cut off as close to the eyelet as possible without causing damage.
Where little bits are sticking out, I have just touched them in with black paint to hide them.
I have fixed and patched up the new PE riggols on the starboard side and prepared all the guns, but still have the port lids to assemble, but they are all ground down so I should have no problems with them.
Here are some pics of the finished port side.
The exception with the port lids is the forward most port on the lower gun deck, this is depicted in the closed position to give a different perspective and point of interest and shows off some of the hinge detailing too.
Well, that's it for now.
sparks
#215 Posted : 15 August 2014 23:56:24
Thanks Robin,
Sorry to hear about your breakages Crying , you must be gutted.
sparks
#216 Posted : 15 August 2014 23:58:56
Thanks Alan
Its been a bit of a slog trying to motivate myself to re-do stuff that was once finished, but I'm glad I did it and I'm almost there BigGrin
Gibbo
#217 Posted : 16 August 2014 00:13:35
Hi Alan
Good to see you're back on your build, your gunport lids look fantastic, lots of tiny work, i've got to re-paint mine, the reds are very different, i was looking at the PE aftermarket parts and looking at your build i'm going to invest in them, good to see the ol' girl back on the go and looking forward to the rest of it.
Paul
#218 Posted : 16 August 2014 00:24:43
sparks
#219 Posted : 16 August 2014 20:23:51
Gibbo wrote:
Hi Alan
Paul
Thanks Paul,
Its good to be back on it.
the PE parts are well worth the investment as unfortunately the Del Prado Victory was short on detail Angry
sparks
#220 Posted : 16 August 2014 20:25:24
stevie_o wrote:
Looks fantastic Alan, glad to see you back on this oneBigGrin
Thanks Steve
Comments much appreciated, its good to be back doing more on the Victory.
Guest (14)
12 Pages «<9101112>
This page was generated in 0.211 seconds.
