24 Pages «<1718192021>»
Up-grading the Del Prado 1/100 Victory Options
#361 Posted : 16 February 2014 23:57:35
Plymouth57 wrote:
Hi Alan.
Thats a thought! I'll give it a try some time, would have to be very careful with the application to avoid 'splodging'! Blink That's the thing I like with the super, the way it 'wicks' itself away out of sight!BigGrin
Good idea there, and I might try that on the diorama tanks, they'll be needing a lot of pipes and bits sticking around the insides! Crying
Hi Robin, the way I use the quick setting epoxy (5 min setting time) on very small parts is to apply using a pin to both the part and the area it is to be fitted, leave it for three minutes then apply to the piece.... have to be careful setting the piece as not cause to much movement.. plus there isn't a lot of wriggle time... need a steady hand but have found success with it..... Let me know how you get on.....
#362 Posted : 17 February 2014 00:40:18
sparks
#363 Posted : 17 February 2014 20:25:39
Nicely done as usual Robin ThumpUp
#364 Posted : 12 March 2014 18:08:08
Many thanks to all the above, very appreciated as always!Blushing
Hi to All again!
This is a little (hopefully) helpful tutorial, which I have decided to include after I passed on its details to another member recently. Although a simple process, it’s not very easy to describe in just words so here it is in my normal pictorial version.
I will not be getting to this stage myself for a very long time yet, but many others are already up there so this is for all of you.
Firstly, I take no credit whatsoever for this handy little technique, I discovered it and used it to good effect on my very first wooden ship kit, Constructo’s “Grimsby” after reading it in the excellent modellers book “The Period Ship Handbook” by Keith Julier (see post #6 in the Reference Books for Ship Modellers sticky thread)
This is a very easy way to simulate the clutter of rigging coils hanging off the Belaying Pin Racks without having to go to all the trouble of really wrapping your actual rigging thread around the Pins (which is really difficult anyway!).
Again, its simple jig time! And this one couldn’t get much more simple as you can see in Photo 1. It is just a plain block of wood with two holes drilled at right angles, one in the top and one in the side. For this exercise, I’ve just done it all without any measuring, but when doing it for real you need to do it more accurately than this! First off, measure the width of your Belaying Pin Rack, the Pins themselves will be fitted into a line of holes in the middle of the rack so half the width and that distance will be how far in from the edge the top hole goes. Next, measure how high up the rack is from the deck. The second hole in the side of the block should be either equal to or slightly shorter than that measurement. If it’s equal your coils will ‘droop’ to the deck, if shorter, they will have the appearance of the finished article in this tutorial (Photo 9). In Keith's book he also describes making this jig up as a series of holes and pegs along the block so you can make the coils in multiples which makes more sense of course!
Also seen in Photo 1, and in position in Photo 2 are the two short dowels. In my earlier reply on Stevie-O’s diary, I mistakenly said I’d used cocktail sticks. When I come to do this on my Victory, I probably will be using them, if not a brass rod even thinner than the cocktail stick! But I realise now that what I actually used was a bamboo skewer so that’s what I’ve used here again. What you need to use will depend on the scale of your ship of course.
To make the actual coil of rope, start with a length of the rigging thread you have coming down to the rack and holding one end tight at Position A in Photo 3, take the thread down the side, around the bottom peg and back up around the top peg, repeating this as many times as you want. However! Before doing that (I just remembered!) make a little slit with a sharp blade in the bottom edge of the block just to the left of the line of the pegs. As you wind the thread around, try to keep the threads one on top of the other as they go around the pegs themselves. It doesn’t matter how the threads are arranged in the vertical part but if you can keep them one against the other at top and bottom, it improves the finished look of the coil for later. Once you have enough rope on the coil, simply pull the excess into that slit at the bottom, this will keep it all tight and you can cut off the rest of the thread without it all unwinding. The next stage is up to you, in Keith’s book he says to give the coil a light brush with thinned down PVA, which, is what I’ve done here. This means a few hours wait before proceeding though. On the Grimsby I applied a few drops of watery super glue with a blunt needle on the ‘shoulders’ and one each where the coil goes around the pegs. Be very sparing with it though! I just found it gave almost instant results (although a few coils had to be sacrificed however, permanently glued to the pegs!) The finished coil is seen in Photo 4.
The following photos are all pretty self explanatory, I’ve just made up a quickie Pin Rack from a bit of Grimsby plank and one of the first Skid Beams that I removed from the Victory during her ‘Oops I didn’t notice that’ refit! (Photo 5) The rigging thread is brought down to the rack and passed through the proper hole where it’s Belaying Pin sits (Photo 6) and the Pin is inserted to fix the thread in position (Photo 7). Leave enough excess thread so that you can move it back and forth until the correct tension etc. is achieved. The next step is very important! When, and ONLY when you are completely satisfied that the rigging ropes are correct, snip off the excess thread close to the bottom of the rack and pin (Photo 8).
Finally, simply slip the finished coil over the Belaying Pin and secure with a drop of PVA. If necessary, a drop of glue around the front will allow the coil to be pulled tighter around the Pin. Photo 9 illustrates the finished article, note that with a whole row of them in place the coils will have a tighter appearance anyway. (This one isn’t glued at all, just placed on top).
So that’s it, much easier to follow in this manner and I hope that some of you will be able to make use of this easy little technique. I’ll join you here in a year or two!
Many thanks Keith Julier!
Bye for now!
#365 Posted : 12 March 2014 23:48:08
Great work Robin and thanks very much for sharing.... this is definitely a technique I will follow when I get to that stage.....Drool Drool .. Appreciate you taking the time to explain in such detail....
#366 Posted : 13 March 2014 00:03:23
karl josef
#367 Posted : 13 March 2014 20:45:52
robin,great idea, I have to keep that in mind :-)
Best regards,
Reiner
#368 Posted : 14 March 2014 01:55:07
Hi Robin.
Looking superp. Look forward to seeing more ian Cool BigGrin
#369 Posted : 14 March 2014 08:33:06
Interesting and a good result.
#370 Posted : 29 April 2014 20:37:51
Hi All!
Many thanks for the kind comments to the above. I used this technique on both the Grimsby and the DelPrado Bounty and it certainly makes the 'tie-up' part of the rigging both easier and a lot quicker! BigGrin
As you can imagine, the poor old Victory is having a bit of a back seat at the moment. I do need to finish the port aft of the hull sides as far as the application of the enamel wash to deepen the shadow effect is concerned, I might try and put a 'before and after' series of photos together to illustrate how it works soon, (that should only take an evening to do and will be a break from barbed wire at least!BigGrin )
See you soon.
Gibbo
#371 Posted : 30 May 2014 00:54:29
Plymouth57 wrote:
Breaking away from the ongoing upper hull construction for a while, this section concerns probably the best way of improving the look of any wooden sailing ship - copper tiling the lower hull. (At least those wooden ships dating from the time of the introduction of copper sheathing of course, the Santa Maria probabably wouldn't be improved by this!!) Probably thousands of modellers have used this method before me but since it forms an important part of this build I'll put it in anyway in case it might help someone.
The copper tiles were made from simple self adhesive copper tape of the kind used either for anti slug protection or dolls house electric wireing. I bought a pack of five rolls for quite a reasonable price on Ebay but still had to go back for another five later! The rolls were 6mm wide and a few metres long. The first job was to cut off lengths a few inches long and pencil mark them every 12mm. I often work in both metric and imperial at the same time! Once marked the 12mm marks were used to scribe the tape (copper side) with the back of a scalpel blade to form the individual tiles.
Once completed, two lines of rivets were pushed into the copper from the back (backing paper side) with the tip of a fine rat tail diamond file, I did start off doing the long edge rivets that way as well but it was taking a hell of a time and was giving me an aching wrist as well! Then I came up with a much better method using a fine toothed dremel type circular saw, just had to roll the saw on its shaft along the edge of the tape, imprinting the rivets as it went - far easier although still hard on the wrist! The photos below illustrate the procedure...
Top left is the rotary tool circular saw used to produce the rivets along the edges of the copper tape.
Top right is a length of the tape with the three stages of production from right to left, firstly the scoring marks into the copper side to produce the individual plates, next the side rivets produced with the point of a needle file from the backing paper side and on the left the finished plates with the long edge rivets in place.
Centre left and Bottom left shows the stern section before the rudder went on and the first rows of plates starting from the sides of the keel and working out and up.
Bottom right shows the completed coppering at the stern up to the water-line including the added rudder. The rudder hinges are non functional, I glued the rudder on (once completed) with the help of two 2mm brass rods drilled into both the rudder and the keel. The rudder hinges are made from lead tape, embossed with the rivets and pre-painted before supergluing on. Also shows the scratch built lower stern below the galleries. The curved section below the quarter gallery was built up from a sandwich of ply pieces, shaped to fit and each one slightly smaller than the one above. This was then sanded to shape and the 'steps' filled with wood filler before the final sanding and painting. The decorative borders are wood strip and the decoration on the bottom is from thin electrical solder bent into shape around a series of cocktail sticks then slightly flattened, trimmed, painted and superglued in place.
Hi Plymouth57, just joined this forum and i am in the process of building the same DelPrado Victory, i am completely amazed at your build of this boat, i very much doubt i will be putting as much detail into mine as you have into yours, but you certainly have given me an insight into what can be done and if you dont mind, incorporating some of it into mine, especially the deck netting and the copper bottom, thanks for the inspiration.
Gibbo
#372 Posted : 30 May 2014 16:43:48
Hi Gibbo!
Many thanks for your kind words and a warm welcome to the forum. I'm glad there's another DelPrado on the way and the very best of luck with yours!
As I've commented in this diary, despite it's obvious flaws and shortcomings, this kit can be made a whole lot better with some hard work and creative thinking!Blink Please feel free to use any of my ideas and techniques (and improve on them if you can!) I'll look forward to seeing your own diary up there soon. That coppering with the cheap tape from ebay is certainly one of the better ways to improve her. I would advise doing the coppering as soon as you have finished, sanded and painted the hull with the bottom black stripe, (the rest can follow on later), the sooner the copper tape is on, the more time it will have to tarnish down naturally as you complete the rest of the ship. Don't forget to give the bare wood below the waterline a couple coats of satin clear varnish first, the better the finish of the hull, the better the tape will stick down.
My Vic is having an enforced stay in dry dock whilst I concentrate of the WW1 diorama, I'm at the point of making the various channels and they are a full time job!
Best of luck again!
Garth
#373 Posted : 30 May 2014 19:44:57
Hi Robin,
Great idea. Thanks for the easy to follow instructions. I will put it to use when I get there on my Victory.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
#374 Posted : 22 September 2014 21:57:06
Many thanks Garth, glad you found it useful!Cool
Well, its been a long time since that last post, but here finally is an update of the Victory! Unfortunately, this instalment is more of a step backwards!
As you probably know, the last few months have been taken up with the Great War Centenary project, The Assault on Messines Ridge. During this time, Victory has been safely (or so I thought!) stored at the back of the attic workroom. A couple of months ago I heard a thud come from the attic from down below. Occasionally something shifts slightly up there and I thought no more about it until a few weeks later when I glanced at the ‘Ol Vic’ whilst retrieving something or other. Ah! Actually, I was searching through some old bi-plane kits from my youth looking for some Lewis guns to nick (I mean re-use!) for the diorama. Something didn’t look right, I was looking directly at the stern but somehow it looked lop sided. Also, what was that table top oscillating fan doing laying on the floor below the ship?
As you can see in Photo 1, the fan on the floor was the reason for the thud and unfortunately, it had not gone quietly, sliding off the pile of boxes to the side of the Vic and simulating a direct hit from a 64pdr carronade on her poop deck!Cursing
The damage is considerable, but at the same time, luckily repairable too as I’ll explain below.
Firstly, the quarter deck hammock frame and net had been knocked clean off, scattering hammocks everywhere! Apart from a slight bending up one end however, the frame and netting is not damaged and simply ‘popped’ off from the bulwarks, this should be fairly easy to put back on. The inner balustrade on the port steps can be seen laying on the quarterdeck in front of the binnacle, again though, no actual damage and it actually clips back on with no glue so fixing back is again a simple task.
Even the port side extra bulwark, seen here broken in two, has a clean break and with a smear of PVA and another touch up with Admiralty Black and Yellow Ochre will be as good as new. The only missing piece as far as I can see is the forward end hammock frame belonging to the broken panel which is easy enough to re-make. The other three frames are present and correct and will just need to be re-attached once the side board is back on. There is a little damage to the actual side timbers just aft of the steps but that may be just where the glue pulled away from the sides during the impact. The main damage in Photo 1 was caused to the poop deck barricade. Three of the square wooden pillars have broken away, (I thought one was gone forever but I later found it hiding beside the starboard cannon under the steps!) Talking of the starboard guns, some of the tackle has come loose and just needs re-fixing with a drop of PVA. About four of the bucket brackets have been broken in half and will need replacing and one of the hammock frames on the netting assembly was bent beyond repair, but again all fixable thank goodness.BigGrin
As that fan bounced over her port side, (probably French or Spanish made I don’t doubt!) it also dislodged one of the upper gun port lids (easiest part to glue back) and pulled out one of the aluminium ‘lead’ pipes, still attached to the lid tackle rope! (Arrowed in Photo 2)
Fortunately, the projectile completely missed that scratch built skylight – if that had gone I really would have been more than a little ‘miffed’!! (Photo 3)Blink The two pieces of plasticard marked with a question mark really had me confused for days. They were painted in Admiralty black and had obviously come from somewhere on the Vic but where? I went back through the last six or more pages on my diary checking on all the work on the poop deck area but couldn’t find any reference to those two bits at all. Finally today, I discovered what they were – in its final corkscrew trajectory, the fan had actually managed to smack into the lower hull – those two flat panels are two of the lowest side entry steps! The quadrant shaped supports are still attached to the hull however so gluing them back is another simple job.Flapper
So that’s the state of affairs at the moment, a week or so of rebuilding and I should be back where she was during her ‘lay off’. Let that be a warning to all ‘storage freaks’ its not just your pride and joy that needs careful placement, its all the rest of the bits and pieces (and potential projectiles) stored higher up too!Blushing
See you after she comes out of the dry dock and Happy Modelling to you all!
Robin.
#375 Posted : 22 September 2014 23:54:38
Hi Robin, really sorry to hear and see the damage that has been done to the old girl but think also you have to be grateful the damage is not more extensive...Crying Crying Crying .. Yes it means additional work to bring her back to her best and I have no doubt with your skills she will once again look absolutely fabulous....Cool Cool .. Will be following to see how the repairs go.... Cool Cool
#376 Posted : 23 September 2014 00:26:39
#377 Posted : 23 September 2014 13:08:03
Hi Robin.
Hope your repairs go okay. look forward to seeing more of your build ian
#378 Posted : 23 September 2014 15:56:50
I am sure you will put this one back to fighting order. Very frustrating when a build gets damaged but sure your skills will sort this one.
sparks
#379 Posted : 23 September 2014 23:02:32
Hi Robin,
Nice to see you back on the Victory build.
Gutted to see the damage caused Crying , but I'm sure you will soon have her ship shape again.
#380 Posted : 24 September 2014 10:21:44
Crying Sorry to hear about the prang looking forward to seeing her back to her old self ThumpUp
Guest (6)
This page was generated in 0.319 seconds.
