Possible area for errors!!!! Options
Oldhorse
#1 Posted : 17 February 2014 15:54:48
Rank: Beginner Level 1
Hi all
Just wanted to tell you about a mistake i've made on the right wing.
It involves the right wing reinforcing spar. It seems possible to place the spar at 180 deg out, as it will fit either ways.
When you come to put this part on, make sure the "cut out notch" is on rib 9...if it is 180 degs out, it will be on rib 7. It seems easy to make this mistake.
Probably a beginners mistake I know....hope this potentially hepls.
Completed:McLaren MP4 - 23
Building:Spitfire
This page was generated in 0.155 seconds.
