Hi Everyone. Thought i would try and put some pics up of my D51. mark 2 attached the following image(s):
Hi MR T. Glad my pics came out. Please could you put this in the right place  . Thanks and best regards. Mark
Hi Everyone. Here is the bottom. Best regards all. Mark mark 2 attached the following image(s):
HI Mark, I'm not on this build yet but looking at your's Mark you have made a great start I can see you are enjoying your build we'll done. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev. Hope your well. This is a fantastic build and would recomend it to all  . Thanks for your support  . Best regards. Mark
Nice to see your build Mark, look forward to seeing more Steve
Hi Steve. Hope you are well. Thanks for your support  . Best regards. Mark
Nice build Mark, You have a nice paint finish. I look forward to seeing more progress
Jase“Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Jase. Thanks for the kind words  . I will post some more soon. I would also like to ask a bit of advice. As you can see i chose to paint the D51 but what i would like to ask is is it best to spray a varnish over the paint. Thanks and best regards to all. Mark
Looks like your enjoying its build, well done!
 Hi Mark looking good Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi MR T. Thanks for moving my build to the right place. I am really enjoying this build  . I think this is one of the top partworks available. Once again thanks and best regards. Mark
Hi Andy. Thanks for your kind words and support. Best regards. Mark
mark 2 wrote:Hi Jase. Thanks for the kind words  . I will post some more soon. I would also like to ask a bit of advice. As you can see i chose to paint the D51 but what i would like to ask is is it best to spray a varnish over the paint. Thanks and best regards to all. Mark Hi Mark
Simple answer in my view is that it is always Better to spray when you can.
Certainly easy to do that for the boiler assembly. The running gear will be more difficult to spray once assembled because of the moving parts; I would be tempted to brush that. It largely depends on your skill and confidence and if you are using a rattle can or airbrush.
You may want to wait until further in the build when you are sure of the relationship between the boiler construction and the Drivers cab.
Hi Jase. Thanks for the advice. I have an airbrush and compressor which i am not to bad with. I will wait until later on in the build . Thanks again for the advice. Best regards. Mark
Hi All. I have since resprayed the front as in pic 3 (the view from the front)as there was some overspray but have now rectified that and will put more pics up soon. Best regards. Mark
Hi All  . Got my next installment of the D51  . At the moment i wont be spray painting only undercoating as there are still parts to be added. Please enjoy.
Hi All  . Got my next installment of the D51  . At the moment i wont be spray painting only undercoating as there are still parts to be added. Please enjoy. mark 2 attached the following image(s):
Hi Mark, Looking good I can see your enjoying this one. All the best Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
