 Thanks Steve The flash makes the launch inner look too glossy its more dull than it shows in the pics and thanks for looking in regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy. your Launch looks Superp. watching this one with great interest. look forward to seeing more Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Hi Ian Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Nice work... Regards Alan
 Hi Alan Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Not much to do this month as its mostly filling in tapers on the hull which I have already done but there were two ladders to make up and the adding of the bow and stern fillets to get the shape in these area's. At the moment they are added but not shaped as I will leave over night for the glue to completely set then it's lots of shaping and sanding in store. regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, Looking good - are the fillets balsa or ply? and are these added by you or are they part of the kit? Steve
 Hi Steve Thanks for looking in and your comments. The fillets are pre-cut and provided with the kit and are of light ply which should make shaping them easyer regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good Andy, nothing like a little therapeutic shaping and sanding to fill your time.... look forward to seeing the results..... Regards Alan
Hi Andy  . The build looks to be going great and it shows. Keep up the fantastic work. Best regards. Mark
 Hi Mark Thanks for your comments and looking in regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All After leaving overnight to let the glue dry properly I got down to some serious shaping at the bow and stern. To the rough sanding I use a wood file which when 1st used can be frightening as it strips back fast and roughly but with experience you know when to stop and let the sand paper take over. There is a fair amount to be taken off at both ends but its soon done so here are the results. regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, Just had a look and you are doing well,plus all that sanding has made the difference did you find ply hard to shape,looking forward to see how that part turns out. Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Nice shaping there Andy, looks fab, will be watching for more updates
 Hi Trev Thanks for looking in and your comments, the ply provided for this part is the light ply variety so quit easy to shape regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Steve Thanks for commenting and looking in regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 01/09/2012 Posts: 111 Points: 306 Location: Nottinghamshire
Stunning work as always. I am really enjoying seeing this one come together.
Dave
 Hi Dave Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy. Superp looking Launch. Realy like the finish. Watching with great interest. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Guest (15)
