 Rank: Beginner Level 1  Groups: Registered
Joined: 21/10/2013 Posts: 10 Points: 13 Location: Westend southLincs UK.
Hi Guys & Guyeses Has anyone else had this; in 'package 13' I have got 4 Items numbered 1but they should be 2off1 and 2off2 does it matter can all bits be used? Ted
Are you referring to Stage 50? You have been supplied with two identical sets of plastic parts. The numbering is the same for both, though some of the duplicates are surplus to requirements, it does not matter which you use.
Hi Tomic Its the bits that make the top arm of rear suspension.
Does what you have reflect the parts shown in the relevant stage numbers of my diary build?
