Parts query Options
Ted the bullet
#1 Posted : 24 February 2014 15:30:32
Rank: Beginner Level 1
Hi Guys & Guyeses
Has anyone else had this; in 'package 13' I have got 4 Items numbered 1but they should be 2off1 and 2off2 does it matter can all bits be used?Huh
TedConfused
#2 Posted : 24 February 2014 15:38:38
Are you referring to Stage 50? You have been supplied with two identical sets of plastic parts. The numbering is the same for both, though some of the duplicates are surplus to requirements, it does not matter which you use.
Ted the bullet
#3 Posted : 24 February 2014 18:12:38
Hi Tomic
Its the bits that make the top arm of rear suspension.
#4 Posted : 24 February 2014 18:21:15
Does what you have reflect the parts shown in the relevant stage numbers of my diary build?
This page was generated in 0.091 seconds.
