3 Pages <123
Stevie's Emhar 1/35 Scale MKIV "Male" Tank - WW1 Diorama Options
#41 Posted : 02 March 2014 11:39:17
Looks fab Stevie, looking forward to seeing the finished product.... Cool Cool
#42 Posted : 02 March 2014 11:47:16
BigGrin Hi Steve
Looking good you could of course go for this as an alternative paint idea
http://www.andreaeurope....1916.html?redirect=true
#43 Posted : 02 March 2014 12:36:21
Thankyou Alan, I will be continuing when I can find some number decals of the right size for the serial, then I can get the tracks primered and klear cote it before the real fun startsBigGrin
Thanks for looking
#44 Posted : 02 March 2014 12:43:18
BigGrin Hi Steve
Hi Andy,
Thanks for looking. That kit looks amazing and I love the cammo, but - that is a MKI, identified by the tail wheel, exhaust baffles on the roof and the long barrelled 6pdr guns. This "Solomon" cammo scheme was only used on MK1 and some MKII tanks - not the MKIV sadlyAngry otherwise I think I would go for it to add some interest.
#45 Posted : 03 March 2014 13:13:12
The pics in this stage show the model after 2 light coats of matt earth wash. The tracks have also been painted with track primer then a layer of pledge over the whole lot ready for the next layer of wash. I chose not to use any decals preferring to go for the painted on look of all numbering and lettering.
#46 Posted : 03 March 2014 13:24:22
And...here are some more pics after a layer of burnt umber wash. Still to come are some oil washes and the exhaust corrosion, slight chipping and drybrushingBigGrin
BTW, completely ignore the lay of the track at the moment, it will be sorted out later as it is not an even distance from the side panels all round
#47 Posted : 03 March 2014 14:04:37
Hi Steve
Top job as usual great stuff.
Trev.
#48 Posted : 03 March 2014 20:35:44
Thanks Trev,
Should get this finished tomorrow - it is going to be on a dio base with one other small kit that I will build soon. I will be working on this dio base and my WWII N.Africa base when the garage is a bit warmerBigGrin
Tomorrow I will give it one more layer of clear cote after any little touch-ups needed when I look at it in daylight and then I will fix the tracks as well.
I will be adding some track grabs to this also and these will be scratch built, I need to make 13 per track. I also have a figure to paint to place in the hatch, there will be 3 other figures on the ground too.
#49 Posted : 03 March 2014 23:47:03
Stevie, weathering is really bringing her to life, wonderful job.....Drool Drool
#50 Posted : 04 March 2014 09:40:20
BigGrin Stunning work Stevie love the rust BigGrin Rgd Martyn
#51 Posted : 05 March 2014 14:52:13
Thanks Alan & Martyn,
Not trying to bore anyone but I'm calling this one done now, this diary will be a useful reference for me as well in case I forget what I did. I have done the final grime layer with oil / thinner mix and a bit of tidying up here and there. The only things left are an unditching beam and the track grabs. There will be some mud as well but I can't add this until the dio is done.
More to come on this one prob in the summer when I have a warm garage againBigGrin
Cheers
#52 Posted : 07 April 2014 21:37:27
Just a small update here for those followingBigGrin
I have made the un-ditching beam and chain, fairly happy with the result. The guy in the hatch is, or should I say was a WW2 russian tanker, but, due to the look of the overalls he can be used as WW1 BritBigGrin. He would normally have had a cap on but this is going to be an "at ease" kind of dio so he could have removed it.
The tank officer is to be looking at some infantrymen recovering a piece of german hardware from a crater hole so is looking suitably relaxedBigGrin
I need to make some track grabs next and the dio will follow from there.
#53 Posted : 07 April 2014 23:36:19
One word Stevie..... stunning......Drool Drool
#54 Posted : 08 April 2014 00:10:49
Dontshootme
#55 Posted : 08 April 2014 08:29:50
Superb,the guy in the hatch just sets it off beautifully.Looking forward to seeing the rest of the dio.
#56 Posted : 08 April 2014 13:12:08
Super work Steve ThumpUp
#57 Posted : 08 April 2014 13:59:48
Looks spot on great weathering a treat to watch you build this
#58 Posted : 08 April 2014 19:08:45
#59 Posted : 08 April 2014 21:38:27
Hi Stevie!
Good to see the 'Giant' back again! You were right about that Russkie, couldn't have been a better pose if you'd designed it yourself! Well done! Cool Cool
Keep them coming! BigGrin
Guest (12)
3 Pages <123
This page was generated in 0.348 seconds.
