problem Options
timebob
#1 Posted : 17 July 2010 12:57:02
Rank: Beginner Level 3
trying to get the right part for the tiller, it does say to retrive the
wood strip from issue 6 i found that this part is not there or ive missplaced
it. anyone got an idea as how to continueConfused
p.s a big thank you to cap stedders well done sir (sorry about the stamps)
RussG
#2 Posted : 17 July 2010 17:01:28
Just a thought, Have you tried using a toothpick, wonderfull little pieces of wood those!!! BigGrin
Happy Building, Russ
ArtfulBodger
#3 Posted : 17 July 2010 21:12:42
If someone with a camera could produce a template, I don't own one. It's a little bit of scratch build although I sympathise with your plight.
ArtfulBodger
Previous Build:
HMS. Bounty
budgie
#4 Posted : 17 July 2010 21:45:18
pm me
email me
what do u require i will gladly help out
got most of launch parts
just happy to help out(making up for misdemeanors in past so don't get soppy)
Mike Turpin
#5 Posted : 17 July 2010 22:47:51
Hi Timebob
You can use any spare offcut of wood you like for the tiller. I had already used all my wood strip because I had snapped one of the supports in the stern of the launch.
This got me thinking so I got an old piece of dark planking and took off a narrow strip to make a square section. I then drilled two 0.6mm holes in the tiller face and used the drill to open them out into a vertical slot, angling slightly downwards. I dropped the new tiller piece into hot water and then put a bit of a curve on it before filing down the end to fit into rudder slot. I'm also using a piece of the brass strip to reinforce the joint. The tiller just needs some varnish to finish it off.
I now reckon I have a slightly refined rudder/tiller which is consistent with my main launch colour scheme of yellow ochre for most of the interior and varnished thwarts.
timebob
#6 Posted : 17 July 2010 23:38:56
well done mike its worth trying thank you
RussG
#7 Posted : 18 July 2010 03:57:48
LOL Sorry Mike LOL Had a couple of beers, but Pepperami, just sprung to mind!!! really sorry!!Blushing
This page was generated in 0.313 seconds.
