 Rank: Amateur Level 1  Groups: Registered
Do you need to do anything to the webbing so that the decal will 'stick' to it? I am using Micro Set & Sol but with no joy. Many thanks Andy "I’m not expendable, I’m not stupid, and I'm not going."
Personally I wouldn't bother as no matter what you do they will not stick and the ones on the harness are perfectly good enough. Spencer
Thanks bloke. A bit of a pain as I like the look of them, as the ones on the harness look a bit faded "I’m not expendable, I’m not stupid, and I'm not going."
