Hi Stevie, this build gets better and better every time I look in.... fab work.... Regards Alan
Thankyou Alan,Robin The tip on the rope coils is very good, took me a while to visualise the jig but I have it now - a variation of this can also be used for ropes coiled on deck too. I really never thought to "pretend" that the coil is actually joined to the rope, you can just tie off a rope a put a fake coil on top - perfect Steve
Lovely work there Steve...A pleasure to look at!!  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Thanks for looking Jonny Issue 101 still! The topgallant shrouds and futtock staves are now all done, I didnt even realise these were there until I got to this issue. Not much to look at really but these are the shrouds at the very top of the masts - no ratlines to go on these though Technically, the ratlines are next (still issue 101 unbelievably) but I'm thinking about going to issue 102 to get all the backstays done - then again no point in delaying the inevitable The other pics just show the top ropes tidied up on deck, as the instructions said to wrap these to the posts and not to the belaying pins I just coiled them up. Steve stevie_o attached the following image(s):
Looking really nice mate
J“Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 17/03/2013 Posts: 192 Points: 524 Location: United Kingdom
Really like what your doing, excellent work, well done. Regards. “Count your age by friends, not years. Count your life by smiles, not tears.”
Lovely work Stevie, cracking looking build.... Regards Alan
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Your build looks great Steve, getting better every time
Hi Steve. Looking superp. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks for the comments everyone Just completed the last remaining job from a previous issue - the gunport lids are now all done on both sides. Not much to show really, firstly the threads were inserted into the lids by supergluing the thread to make a point, this was pushed through from the inside of the hatch so it could be used again to insert into the hull holes. PVA was used to secure the thread to the hull and when dry was pulled tight down through the lid and secured underneath with superglue. So much work involved in the gunports overall and due to the repetition takes a lot of time. Note to self: Make sure my next partwork contains cast metal gunport lids Steve stevie_o attached the following image(s):
Forgot the rest of the pics stevie_o attached the following image(s):
 Wow lovely work Stevie the gun ports look bril  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi Steve. Superp job on your gun port lids Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Good stuff there Steve. I know how your are enjoying your current issues because I'm there myself and they take a loooooooong time and lots and lots of patience. Enjoy. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Thankyou for the comments again guys! Well, it could be put off no longer - The ratlines I decided to go for the method used in the instructions and the Official build diary - this is where the ratlines are pushed through each shroud with a needle. The knot tying method is much more time consuming and can result in the knots looking out of scale. First thing was to find the right size needle, it has to be able to take the .25 thread but as thin as possible so as not to make to big a hole through the shroud. I also made my own needle threader (1st pic) as the ones that come with sewing kits kept breaking after a few uses, my home made worked fine though The port formast ratlines are now done and I found the top shrouds much easier as the needle was longer than the width of the 6 shrouds so could be pushed through in one go, the lower ones I had to do individually. It was then a case of trimming off after sealing with pva and adjusting the shrouds and lines to a more natural look. I really wasnt being too fussy about this but my main concern was that I had no ratlines that "drooped" the wrong way, ie they werent curving upward, only dropping downward or pulled straight. Im pretty sure on the real ship these wouldnt be exactly uniform, some will be more stretched than others. I reckon this is going take me a week to get them all done so will post up here when finished, and amazingly I am still on issue 101 - there is no end to it Steve stevie_o attached the following image(s):
Joined: 01/09/2012 Posts: 111 Points: 306 Location: Nottinghamshire
Wonderful craftsmanship sir, looks really good.
Dave
 Hi Steve It one of the tedious jobs that have to be done, looking good though regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Cracking work Stevie, looks fab....  ,, I'm still undecided whether to simply have the ratlines pushed through the shrouds or whether to have them tied.. suppose I will make that decision when I get to that stage..... Regards Alan
Hi Steve That looks all too familiar, job well done. Looks great. like your threader as well, good idea. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Guest (13)
