Pack 5 - parts replaced Options
#1 Posted : 17 March 2014 20:43:11
Hi All, BigGrin
Have just received my part 5 replacements Cool
The packing box was millimeter perfect (almost)
The main wing spar was not broken, but has a slight curve
over it`s length, Crying due to the fact that the part was
bent very slightly too fit.
Can this curve be forced out when building the wing, if clamped
to hold the main spar straight? Confused
Please advise if you have a possible answer Blink
#2 Posted : 17 March 2014 23:49:07
Hi Del,
Yes you can build the curve out of the main spar what you will find is that when you build the whole wing with all the spars and ribs you would be very unlucky if there was a slight difference as the wings are so strong when put together,this is the reason why I build my wings in one go so they set straight.
Trev
#3 Posted : 18 March 2014 08:46:57
Have you tried steam and press as you woiuld do a ships frame if it was warped?
This page was generated in 1.282 seconds.
