16 Pages «<1011121314>»
Mantua's RMS Titanic Options
#221 Posted : 13 March 2014 09:46:01
jase wrote:
Nice to see the planking underway. how do you intend to recreate the steel plates that the jul was actuly made of?
Thanks Jase and you really know how to ask relevant questions.BigGrin BigGrin .... The hull is double skinned plus there are layers of ply etch showing all the hatches and portholes and am thinking of how to modify the ply to show the plating.... Will probably be purchasing additional ply, as thin as I can find it and see what I can do from there... Not to keen on using plasticard or metal tape.. still I have time on my hands to think about this one... any ideas would be welcome.....
For me the hull finish is going to be key to an authentic looking model. The problem is you need to replicate lots of rivet detail too. If it was me I would be tempted to go down the plastic card rout which then gives you some rivet options. you don't need to cut every plate you can do them in strips with scribed joint lines.
you might find this site interesting on riveting, you will need to emulate dome head rivets.
http://www.largescalepla...veting_1/riveting_1.php
#222 Posted : 13 March 2014 10:13:01
Hi Alan,
I think rivets would look great on this but they will be very small at this scale. A 38mm diameter rivet would scale down to about 0.2mm, you wont be able to create individual rivets at that scale.
A pounce wheel used very lightly can produce very small dots on the reverse of some 0.25 tin or brass sheet (I have tried it) but its hard to keep the pressure even so the rivets are the same.
experten
#223 Posted : 13 March 2014 15:43:54
Groups: Registered, Official Builds
It would cost a small fortune (in addition) but there are these;
http://www.archertransfe...SurfaceDetailsMain.html
I have used these, and they are great. I'm not sure what size you might need, but there are one or 2 choices.Confused BigGrin Confused
Tired, Old, and Cranky!
#224 Posted : 13 March 2014 21:34:18
"Your 14 inch SOTS against her,,, maybe it could be used as a figurehead"
E'er, ruddy cheek! LOL LOL LOL
Love it, love it, love it!BigGrin Best comment ever!
Keep them coming Alan!
#225 Posted : 13 March 2014 23:26:28
Thanks for those comments and link... gives me some options to consider... I agree, the plating is an important feature of the hull but am just not sure whether you really would be able to see the rivets at this scale... One thing I wouldn't want to see is the rivets being too out of scale..... Lots of pondering to do.....
Thanks again Jase.....
#226 Posted : 13 March 2014 23:29:41
stevie_o wrote:
Hi Alan,
Thanks for those comments Stevie, appreciate your input.... Have been given one or two options that look quite promising so will see what I can come up with.... Some test pieces need to be done here I think....
Thanks again
#227 Posted : 13 March 2014 23:32:00
Thanks Mark, this really does look promising so am now on the hunt to see if there is a supplier here in the UK.... If not I just may be tempted to purchase a couple of test pieces from the states..... Appreciate the link...
#228 Posted : 13 March 2014 23:34:35
LOL LOL .. Thanks Robin, happy it made you smile..... BigGrin BigGrin
#229 Posted : 18 March 2014 23:02:04
Hi all, so made a start now at sorting out the profile of the stern... New balsa blocks were applied and roughly shaped as a starting point.... Hopefully now everything I was saying on earlier posts relating to the stern profile will be a lot clearer.... The first photo shows how the instructions produce a rounded stern both from port to starboard and deck to keel....Cool Cool .. Next photo's shows how the first two facets should look. To get this look meant applying individual shaped planks running up and down rather than the standard way of bow to stern... Everything is still just rough at the moment, sanding, filling and the application of the second plank layer will I think give me the correct profile I'm after.... Tomorrow hopefully will continue the short planking round the other side..... Long way to go yet before I'll be happy with it.....
#230 Posted : 18 March 2014 23:18:40
BigGrin Hi Alan
Its certainly a different way of building up the stern , best of luck with it
#231 Posted : 18 March 2014 23:32:52
BigGrin Hi Alan
Thanks for looking in and commenting Andy..... As they say, there is more than one way to skin a cat....LOL .. Am confident this will give me the profile I'm after and I think this way makes life a lot easier in helping me achieve it....
Thanks again
#232 Posted : 19 March 2014 02:09:24
Hi Alan.
Definetly looks more the shape that it should be. Hope it works out OK. Will be watching your progress with great interest Ian.
#233 Posted : 19 March 2014 08:29:33
Hi Alan, Profile does look improved at this point. Your solution now is built higher than the ribs I notice, I hope that isn't going to cause you a problem further down the line when plating the hull. watching with much interest.
#234 Posted : 19 March 2014 23:02:09
ian smith wrote:
Hi Alan.
Thanks Ian, appreciate your comments..... I'm sure it will work out in the end, will just persevere until it does.... Cool Cool .. Back on the SOTS right now but hopefully back on this build this weekend.... Cool Cool
Thanks again
#235 Posted : 19 March 2014 23:08:23
Thanks Jase, am pleased you think it's an improved profile and yes,it is built higher than the ribs just now, has to be to achieve what I'm looking for.... Cool Cool .. I am also aware it is likely to create some problems further down the line when plating and will just have to find solutions for that too... Basically I had two choices, build as instructed and end up wishing I had done something about it every time I looked at the model or, grasp the nettle with both hands and have a go at trying to put it right.....Cool Cool .. Will just keep at it and I'm sure I'll get there in the end.....Cool Cool It's a journey after all....
Thanks again
#236 Posted : 30 March 2014 22:26:12
Small update, planking has now started in earnest, have also added the top plank but first applied masking tape to the deck edge to ensure I didn't accidentally glue the planks and deck edges together...Blink Blink ... More soon.....
#237 Posted : 30 March 2014 22:32:26
DJS
#238 Posted : 30 March 2014 22:35:37
Hello Alan,
Superb work, having someone else building the Titanic is really useful. I am wondering if the dip I am trying to build out of mine should actually be present as it looks like yours does the same thing.
My rudder area is also nothing like yours, or pictures of the real Titanic, so I am thinking that scale wise this model is a lot more accurate.
Dave
#239 Posted : 30 March 2014 22:49:38
stevie_o wrote:
Fantastic AlanBigGrin Love this build and with the hull shape it looks a joy to plank, not sure about how difficult the stern is going to be though.
Fab job,
Thanks Steve, appreciate your kind comments.... So far planking hasn't really been a problem so yes, she is a joy... The stern has already had to be remodelled and am happy with how it is so far... Still more remodelling of the stern to be done yet though.... Cool Cool
#240 Posted : 30 March 2014 22:56:30
DJS wrote:
Hello Alan,
Dave
Thanks Dave, thanks for looking in and commenting... The dip you see in the deck area is supposed to be there so I wouldn't be tempted to remove it or level it off.... The stern section on this kit is nothing like actual ship and I've had to spend a fair amount of time looking into reshaping the whole back end.... more to be done yet... Cool Cool
Titanic is a ship my wife loves, she has watched and read everything she could find on this icon and it was her idea to get the family together and get this for me.... At this scale there is masses of extras that can be added to her hence the reason I am really enjoying this build.... Will also be nice to bounce ideas of each other.... Cool Cool
Thanks again..
Guest (7)
This page was generated in 0.263 seconds.
