16 Pages «<7891011>»
ARPurchase's build of the D51 Options
#161 Posted : 19 March 2014 23:51:44
BigGrin Hi Tony
Thanks for looking in and please feel free to use any of my idea's its what the forum is for and an honour that you would think it good enough for your own build
#162 Posted : 19 March 2014 23:58:26
BigGrin Hi Jase
Thanks for your comments as always
#163 Posted : 20 March 2014 00:10:53
BigGrin Hi Derek
Thank you for your comments much appreciated
#164 Posted : 20 March 2014 00:11:41
BigGrin Hi Alan
Dennis
#165 Posted : 20 March 2014 08:23:10
Hi Andy,
Must say I like the idea with the sight glass gauges. Really excellent.
Dennis
#166 Posted : 20 March 2014 08:28:38
Nice work on the glasses Andy ThumpUp
#167 Posted : 20 March 2014 10:38:47
BigGrin Hi Dennis
Thanks for looking in and your comments, very much appreciated
#168 Posted : 20 March 2014 10:39:42
BigGrin Hi Tom
experten
#169 Posted : 20 March 2014 16:07:08
Groups: Registered, Official Builds
Hi Andy,
Looking at yours is making me question my decision to not paint mine. Yours is looking fantastic! How did you hollow out the water gauges? Great little detail to add!
Tired, Old, and Cranky!
#170 Posted : 20 March 2014 20:38:06
BigGrin Hi Mark
One thing I will say before I explain how I did it is this anyone attempting this mod will need to realise it will destroy the original parts so once done its carry on or buy new parts to replace them.
The central unwanted centre sections were removed using the cutting wheel on my 5 speed rotory tool, then just a little tidying up with a file. After that sections of 1mm x 1mm were cut to length and fitted to make up the cage's ready for painting.
After the painting is finished the sight glass and 3 safety glazed panels will be fitted
#171 Posted : 20 March 2014 21:35:55
The running board has been made up painted and fixed to the left side of the engine. There may be some fit problems lining up the sand pipes with the board cutouts , I just needed to adjust the central pipe.
mark 2
#172 Posted : 21 March 2014 16:29:10
Hi Andy.
Your build is looking fantastic.
I Love what you have done with the water gauges looks great.
If i had not glued mine before you, Then i would have copied you BigGrin.
Best regards.
#173 Posted : 21 March 2014 16:47:55
BigGrin Hi Mark
Thank you for the kind wordsBlushing , This is what the forum is about sharing ideas and improving finishes where possible
#174 Posted : 21 March 2014 19:58:22
#175 Posted : 21 March 2014 21:33:10
BigGrin Hi Steve
Thanks for looking in and your comments , there's still more to come this month on the backhead
#176 Posted : 22 March 2014 19:03:14
The Backhead mods are now done the outer glass has been added to the sight glases and the candy cane central tubes put in place.
I then added the gauge decals kindle provided by Roy to the gauge faces and finally when dry I used Glue n Glaze to form the glass faces, you may notice that one of the larger gauges its still to clear properly.
That concluded this months build
mark 2
#177 Posted : 22 March 2014 19:29:28
Hi Andy.
That looks absolutely fantastic Love Drool.
Very impressive.
I Love the weathering around the fire doors.
The decals look great and i will go the same rout as you if you don't mind.
Best regards.
#178 Posted : 22 March 2014 20:40:10
BigGrin Hi Mark
Thanks for looking in and your comments and by all means use whatever you wish on your build. The weathering looks even better in real life as the flash bleached it out a little
Warthog
#179 Posted : 22 March 2014 20:45:42
Awesome work Andy Drool looking very used and realistic. Cool
Spencer
#180 Posted : 22 March 2014 22:29:08
BigGrin Hi Spencer
Thank you for looking in and your comments
This page was generated in 0.192 seconds.
