 Hi Tony Thanks for looking in and please feel free to use any of my idea's its what the forum is for and an honour that you would think it good enough for your own build regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Jase Thanks for your comments as always regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Derek Thank you for your comments much appreciated regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Alan Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 08/08/2013 Posts: 184 Points: 567 Location: Runcorn
Hi Andy,
Must say I like the idea with the sight glass gauges. Really excellent.
Dennis
Nice work on the glasses Andy
 Hi Dennis Thanks for looking in and your comments, very much appreciated regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Tom Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Pro   Groups: Registered, Official Builds Joined: 10/02/2012 Posts: 475 Points: 1,237
Hi Andy, Looking at yours is making me question my decision to not paint mine. Yours is looking fantastic! How did you hollow out the water gauges? Great little detail to add! Tired, Old, and Cranky!
 Hi Mark One thing I will say before I explain how I did it is this anyone attempting this mod will need to realise it will destroy the original parts so once done its carry on or buy new parts to replace them. The central unwanted centre sections were removed using the cutting wheel on my 5 speed rotory tool, then just a little tidying up with a file. After that sections of 1mm x 1mm were cut to length and fitted to make up the cage's ready for painting. After the painting is finished the sight glass and 3 safety glazed panels will be fitted regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All The running board has been made up painted and fixed to the left side of the engine. There may be some fit problems lining up the sand pipes with the board cutouts , I just needed to adjust the central pipe. regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy. Your build is looking fantastic. I  what you have done with the water gauges looks great. If i had not glued mine before you, Then i would have copied you  . Best regards. Mark
 Hi Mark Thank you for the kind words  , This is what the forum is about sharing ideas and improving finishes where possible regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice work Andy, love following these D51 builds, some very good work being done here Steve
 Hi Steve Thanks for looking in and your comments , there's still more to come this month on the backhead regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All The Backhead mods are now done the outer glass has been added to the sight glases and the candy cane central tubes put in place. I then added the gauge decals kindle provided by Roy to the gauge faces and finally when dry I used Glue n Glaze to form the glass faces, you may notice that one of the larger gauges its still to clear properly. That concluded this months build regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy. That looks absolutely fantastic  . Very impressive. I  the weathering around the fire doors. The decals look great and i will go the same rout as you if you don't mind. Best regards. Mark
 Hi Mark Thanks for looking in and your comments and by all means use whatever you wish on your build. The weathering looks even better in real life as the flash bleached it out a little regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Awesome work Andy  looking very used and realistic. Spencer
 Hi Spencer Thank you for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
