Beak platform Options
luigione
#1 Posted : 21 March 2014 18:38:29
Hi all, I've just finished assembly of the beak platform and I've noticed that it only touches the frame at the front and the deck at the rear. The only way I can gat it to touch all the frames is to bend it, is this correct?
Luigi
#2 Posted : 21 March 2014 18:58:07
we have not reached that yet in attaching the beak to the hull,so don't worry, I'm sure all will be revealed soon.
luigione
#3 Posted : 21 March 2014 23:01:24
The part I mean is the one from issue 43 of Tomick's build
#4 Posted : 21 March 2014 23:52:47
hi, it sounds like you may have a distorted beakhead prow, the side pieces should touch all the frames and the forecastle sides,(fo'castle) it may be easier to sand the frames with a long sanding block so that they all line up.
luigione
#5 Posted : 22 March 2014 00:29:41
Looks like I'll have to go with the bend option, it's only a couple of mm so shouldn't be noticeable
