 Rank: Pro Groups: Registered
Joined: 27/10/2012 Posts: 146 Points: 427 Location: London
Hi all, I've just finished assembly of the beak platform and I've noticed that it only touches the frame at the front and the deck at the rear. The only way I can gat it to touch all the frames is to bend it, is this correct? Regards Luigi
we have not reached that yet in attaching the beak to the hull,so don't worry, I'm sure all will be revealed soon. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
The part I mean is the one from issue 43 of Tomick's build
hi, it sounds like you may have a distorted beakhead prow, the side pieces should touch all the frames and the forecastle sides,(fo'castle) it may be easier to sand the frames with a long sanding block so that they all line up. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Looks like I'll have to go with the bend option, it's only a couple of mm so shouldn't be noticeable
