Binnacle Options
Glen
#1 Posted : 22 March 2014 11:45:37
Hi all,
I have made the Binnacle, but now I'm stuck on what to use foe the two compasses and the lamp.
Has anyone made these things, and what out of eg wood, metal or plastic.
Thanks,
GlenBigGrin
Roger the Cabin Boy
#2 Posted : 22 March 2014 12:44:00
Glen wrote:
Hi all,
Thanks,
GlenBigGrin
I am sure both of these have been maid in at least one build diary, but forget who's it was, however they used cocktail sticks painted up for the lamp as I recall.
Glen
#3 Posted : 22 March 2014 12:58:44
Thanks Jase, I have tried all sorts of things, but don't look right.
I going to try a masthead light next, and for the compasses I thought about two very small tacks with there heads filed flat, and stuck on a piece of square wood, then painted grey.
Glen
Roger the Cabin Boy
#4 Posted : 22 March 2014 13:08:50
Hi Glen, this may help...
http://forum.model-space...aspx?g=posts&t=4698
Glen
#5 Posted : 22 March 2014 13:26:55
Thanks Gandale, that looks good, now I will get some brass rod and have a go.
GlenBigGrin
Roger the Cabin Boy
#6 Posted : 22 March 2014 14:18:20
Hi Glen,
Bernds guide is excellent and you won't go far wrong if you follow that one. I used a brass pin head for the center, the kind you get in a picture hanging kit, the compass parts were done with the heads of those brass split pins for holding sheets of paper together and the whole binnacle was made using tin sheet and clear acetate.
Page 14 of my diary shows the end result although not very close up.
Glen
#7 Posted : 22 March 2014 17:55:39
Thanks for that Steve, another option to have a go at.
Glen
Roger the Cabin Boy
This page was generated in 0.272 seconds.
