Simple Primer Question Options
Eaglejay
#1 Posted : 20 July 2010 22:10:03
Can I use the Matt White that came with the complete paint set. If not can anyone suggest a good alternate?
Thanks!
#2 Posted : 20 July 2010 23:01:30
I don't know how well it will work as a primer. Primer usually has high adhesion and a good colour cover. I don't know how well the white will cover, although acrylic paints seem to stick well.
I usually use Halfords white primer. It seems to work on wood as well as metal. That's as long as you don't mind spray cans of course.
amipal
#3 Posted : 21 July 2010 00:30:49
I'm using Vallejo White Primer prior to painting any part of the model. Working okay as a base, particularly for lighter colours.
submariner
#4 Posted : 21 July 2010 12:27:25
Rank: Beginner Level 1
Hi
I am using Primer Super spray can from B&Q works great
benny
#5 Posted : 21 July 2010 21:36:12
hi all..dont use the acrylic paints on the brass eyebolts it doesnt stick use a spray paint
cheers benny
This page was generated in 0.197 seconds.
