Joined: 18/03/2010 Posts: 55 Points: 135 Location: Lordswood, Chatham
Can I use the Matt White that came with the complete paint set. If not can anyone suggest a good alternate?
Thanks!
 Rank: Pro  Groups: Registered
Joined: 23/09/2009 Posts: 138 Points: 422 Location: Surrey
I don't know how well it will work as a primer. Primer usually has high adhesion and a good colour cover. I don't know how well the white will cover, although acrylic paints seem to stick well.
I usually use Halfords white primer. It seems to work on wood as well as metal. That's as long as you don't mind spray cans of course.
Joined: 20/04/2010 Posts: 141 Points: 426 Location: Worthing, United Kingdom
I'm using Vallejo White Primer prior to painting any part of the model. Working okay as a base, particularly for lighter colours.
 Rank: Beginner Level 1  Groups: Registered
Joined: 27/03/2010 Posts: 8 Points: 14 Location: Oxfordshire
Hi
I am using Primer Super spray can from B&Q works great
Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
hi all..dont use the acrylic paints on the brass eyebolts it doesnt stick use a spray paint cheers benny
