Period Ships
HMS Victory
HMS Victory - Discussion Forum
Belt & Disc Sanders-anyone got any recommendations?
Hi all, I have been looking at small hobbyist combined belt and disc sanders, but have no idea what is a good make. Has anyone owned one of these? Was it any good? What would be a good price to pay? Seen some on ebay for as little as £25. Thanks in advance
 Rank: Pro Groups: Registered
Joined: 30/03/2010 Posts: 126 Points: 335 Location: Bradford West Yorks
hi Cpt Birdseye if its any good to youI am using a dremel 300 series its a bit strange at first but once you have got used to it there is no problem the golden rule is dont be to heavy handed Peter
Thanks for the reply Peter, but i'm looking for something a bit bigger, but will still sit on a bench.
Any ideas anyone?
Joined: 23/04/2010 Posts: 13 Points: 35 Location: south lincolnshire
Hi Skip Axminster.co.uk do a couple of models starting @ £51. regards Ted Time not spent in the workshop is time wasted
Joined: 01/04/2010 Posts: 7 Points: 21 Location: Rayleigh, Essex
If you can still find one, Bohler Minitools of Germany used to make a great mini belt sander. Bohler mini belt sanderThere is also a little 'dock' with guide that can be bolted to the workbench thathelp you introduce the material to the sander for nice, accurate 90deg work. Bohler mini belt sander in dockHTH., -- Streaky.
Joined: 27/03/2010 Posts: 188 Points: 614 Location: Llandudno
streaky wrote:If you can still find one, Bohler Minitools of Germany used to make a great mini belt sander. Bohler mini belt sanderThere is also a little 'dock' with guide that can be bolted to the workbench thathelp you introduce the material to the sander for nice, accurate 90deg work. Bohler mini belt sander in dockHTH., -- Streaky.  I want a work shop like that Bob
Period Ships
HMS Victory
