Worth all the effort Andy, lovely job..... Regards Alan
 Hi Ian Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Alan Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, Have you decided yet if you are going for a natural build or a painted one, I'm thinking of painting the Trafalgar colours but I understand there is some nice hardwood supplied with this kit which may look nice with a bit of varnish. Steve
 Hi Steve You are right about the nice hardwoods for the hull and will be starting the secondary planking in the next issue. As for a finish im leaning more towards a natural finish with perhaps the use of drawing inks to stain where needed. All this of course will hinge on the finish I can get on the hull but we will see. If you go for the painted version then it will be a nice contrast between the two builds. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
I was thinking the same Andy, Think I'll paint then so we can have 2 finishes on here. I'm going for the red/white/black with copper hull, I think the masts are left natural anyway. Steve
 Hi All This month its the start of the secondary planking but before that was applied I painted all the lower gun port holes matt black as doing it beforehand prevents it getting on the second set of planks. The transom was the 1st part to be done and then two layers of the hull planks were added , soak the planks where they curve around the transom to prevent splitting . Slow work but pays dividends getting the planks aligned correctly at this stage. regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Andy, That hull looks great. WTG Happy building Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Andy Looks good what wood are you using for second planking. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Looking good.... Regards Alan
 Hi Del Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Trev Thanks for looking in and your comments. AS for the wood used so far I think the upper light planks are Lime wood and the lower planking will be of a mahogany. There is I plethora of nice hard woods in this kit and its a little gem to build. regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Alan thanks for looking in Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Added more upper planking today about half way up now, I also added one of the lower hardwood planks to show the contrast between the two. More soon Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Coming along nicely Andy.... Regards Alan
Lovely work Andy, watching and learning for when I get to this stage Steve
 Hi Steve Thanks for your comments and looking in Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All The upper hull planking has now been completed apart from a couple of fillets at the bow, next is to carry on with the hardwood lower hull then start adding more deck furniture. More soon Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
coming on a real treat andy,mouth watering. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
 Hi Karl Thanks for looking in and your comments Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (18)
