27 Pages <12345>»
George1 Build Options
George1
#41 Posted : 10 April 2014 07:57:20
Issue 5 joined onto previous issues.
Noted ply parts a lot harder material than previous re cutting out.
Thought issue 6 would be with five as due date 10th., but after inquiries told that we are going to stay one week behind now with issue 6 only next week.
George1
Building HMS SOTS
jock
#42 Posted : 10 April 2014 08:03:42
Looking good I can't wait till next TuesdayCursing
Previous builds
Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour
http://jockspage.webs.com/
George1
#43 Posted : 10 April 2014 08:09:19
Hi jock.BigGrin
Yes I think they are just saving their bums by being one issue behind even though they may already have it. If there is another shipping problem then they've got that week to overcome it before next is due.
It is annoying. Mad
George1
Building HMS SOTS
#44 Posted : 10 April 2014 15:42:32
hi george,doing a great job,starting to look the part. well done.Cool
bb1949
#45 Posted : 10 April 2014 15:43:57
Hi George. You appear to be making good progress. Perhaps it was worth the wait. I noticed a comment suggesting the issues are out on Tuesday's! Share my anguish as I have to wait until Thursday. But I do get to enjoy your progress in the interim.
#46 Posted : 10 April 2014 18:46:11
Nice work George, like I have said before, at this stage you are always way ahead of your issues / deliveries and it can be frustrating to have to wait before continuing. When you start planking however you will find that the issues are arriving at twice the speed that you are progressing so you should then be getting your deliveries just when you are ready for themBigGrin
#47 Posted : 10 April 2014 21:22:12
BigGrin Nice work georgeCool
George1
#48 Posted : 11 April 2014 02:56:41
Thanks karl.BigGrin
Your comments always appreciated. Cool
George1
Building HMS SOTS
George1
#49 Posted : 11 April 2014 03:01:35
Hi bb1949
Yes mine came thursday. (Yesterday Number 5)
Like they say when planking starts we might be wanting extra time. BigGrin
I'm still envious of those with up to issue 7 though.BigGrin
George1
Building HMS SOTS
George1
#50 Posted : 11 April 2014 03:05:28
Hi stevie_0
Thanks for comments appreciated always.Cool
Yes regarding planking from the builds I've looked at it will be a lot more time involved each issue than the current all done in less than two hours. BigGrin
George1
Building HMS SOTS
George1
#51 Posted : 11 April 2014 03:07:16
Hi arpurchase
Appreciate your comments.Cool
Getting there slowly. BigGrin
George1
Building HMS SOTS
bluedot0
#52 Posted : 11 April 2014 04:34:53
Hi George1
I've been around a bit, I've been a member here for a while now......
I'm just collecting at the moment as I have several other projects that I want to complete before I reopen the shipyard to another ship...not enough dry docks availableBigGrin.....
Phil
You only live once, but if you work it right, once is enough.
Building - Bismarck, Akagi, Warspite, Gato, USS Enterprise (carrier) and D51
skyfire
#53 Posted : 11 April 2014 07:35:15
I'm up to issue 5, but need to finish a few other ships first, before I start building her.
George1
#54 Posted : 11 April 2014 07:52:30
Hi bluedotO
Thought you might have been a long time member but hadn't seen name till comment I made.
Looks like you'll have a great collection eventually. Cool
George1
Building HMS SOTS
George1
#55 Posted : 11 April 2014 07:58:55
Looking at those who have had their first 7 issues regarding their build diaries and the much easier situation of joining false keel together in one piece I'd say it's probably better in the long run to have a number of issues before starting build. Some overseas members who purchased whole lot of issues in one box must have been thrilled. Too much for me financially in one hit. BigGrin
Be pleased to see your build of SOTS when you do start on it.
George1
Building HMS SOTS
bb1949
#56 Posted : 11 April 2014 11:34:52
Hi George I am right side now and accompanied by my mentor!BigGrin
George1
#57 Posted : 11 April 2014 15:08:20
That looks a lot better. We can see now you look like a modeller. BigGrin
Can't make out your mentor though.Huh
I'm a bit slow so you may need to explain.Confused
George1
Building HMS SOTS
bb1949
#58 Posted : 12 April 2014 02:18:33
Yes it is a bit small. I jokingly refer to Buzz Lightyear as my mentor and whilst a bit of family fun I do relate to the character, hence the mounted shirt in my study.
I thought you might like to also see the 'smoothing" tools I use for some of the detailed working, including planking (which will come later) I make these from strips of right angle aluminium (about 75 mm long)using double sided tape on one of the outside faces and attach finer grades of glass paper / wet and dry. I find these very useful and effective. I can also use them to get a reasonably square edge on strips strips, placing the strip on a slightly raised board and then running the 'sanding strip' along the face to give a 'squarish edge'.
Hope photos help (including the one of Buzz)BigGrin
bb1949 attached the following image(s):
George1
#59 Posted : 12 April 2014 04:06:39
Hi bb1949
Understand now your mentor. Saw pic behind you but couldn't make out details. BigGrin
Great idea re aluminium angle for sanding purposes as you've described. I just happen to have some pieces of aluminium angle as cut-offs when I used previously for roof top finish and sides of entry recess for a dog kennel so will look at making up a sander with them.Cool
Any ideas are always welcome. BigGrin
I'm certainly gonna' need all the help possible once we get to planking stage. BigGrin
George1
Building HMS SOTS
bb1949
#60 Posted : 16 April 2014 14:18:58
George I see in one of your more recent photos you have "trial fitted" part 16 which is the bulkhead from issue 5. Did you have an issue in getting it right angle to the false keel. I trial fitted mine and found it was out by at least 2mm and if I forced it square that tended to warp the false keel. My remedy is to take the edge off the side blocks of timber used to strengthen the join at that point but leave the central hole alone which is slowly bringing back the alignment. Issue 6 tomorrow BigGrin
27 Pages <12345>»
This page was generated in 3.729 seconds.
