As i received my first shipment this week (the abo is just starting in Austria), i couldn`t resist and start the build immediately. So here are my fist pictures: What a huge model this will be! Greetings, DaDokta DaDokta attached the following image(s): Greetings, Walter
Good to see another MP4/4 underway
A little update: DaDokta attached the following image(s): Greetings, Walter
Joined: 26/04/2014 Posts: 1,495 Points: 4,397 Location: Essex
I like the idea of putting the marlboro decals on the rear wing before assembling it. I was going to wait and do them all at the end but I think that the rear wing will be a lot easier to do before assembling. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
Joined: 27/06/2011 Posts: 437 Points: 1,321 Location: milton keynes
Hi DaDokta Essentially your placing a black decal on a black surface hence all the fine line detail is blending into the back ground so to speak. therfore to highlight the decal fine lines, a lighter shade would need to be painted onto the suface of the part before applying the decal. regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Thanks Dan! Greetings, Walter
Joined: 20/12/2012 Posts: 17 Points: 51 Location: Essex, UK
dandare wrote:Hi DaDokta
regards Dan That's a good point Dan, I'll bear that in mind too .
I've bought the Museum Collection decals as well and was considering what to do next. I'm slightly in a muddle over this as I'm minded to apply aircraft modelling procedures here as well.
When applying decals to a model aircraft, I'd normally lay down a coat of Future acrylic (Johnson's Klear Floor polish) which will protect the decals/paint layer already present and give the new decals a nice smooth surface to "settle" down on. A further coat of Future would then seal the whole lot in and provide a nice glossy, hard as nails finish to the body work.
Would you agree that this will work with this model as well??
Thanks,
Grant.DeAgostini ModelSpace Mitsubishi A6M2b Zero DeAgostini ModelSpace Senna MP4/4
Arrow Wolf wrote:dandare wrote:Hi DaDokta
Thanks,
Grant. Hi Grant Sorry to run on your thread DaDokta As the finish of the MP4/4 is glossy already, i would apply the "sponsor" decal straight on! then run a clear coat to seal, but for the carbon decal (if you have these) a base coat of colour (be it gun metal, silver or gold etc) to help them stand out would need to be applied. then a suitable clear coat, matt satin or gloss. for the most part i would suggest just adding the sponsorship decals if you want your model to emulate the car that we all know was one of the most fantastic cars to ever race. regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
DaDokta your build is coming along very nicely looking forward to seeing how the carbon comes out on the nose! (make sure to keep us up to date, we all love seeing builds progress) Regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Finally i could finish the rear wing! The first time i applied the decals, i destroyed all the work in the end. I applied a coat of varnish over the decals - but the end part of the wing has decals on both sides. I turned the part over too soon and the varnish together with the decal on one side stuck with the cardbord i do my spraywork on. So i had to reorder another set of decals and start over again!DaDokta attached the following image(s): Greetings, Walter
DaDokta What some brilliant detail in these modelling parts. Nice to see your adding your own stamp on the kit I bet you will end up with a stunner of a model Happy Modelling
Thanks Tony! Greetings, Walter
 Rank: Semi-Pro Level 2    Groups: Registered
Joined: 14/03/2013 Posts: 96 Points: 287 Location: England
Looks great. The inking really adds to the detail. I haven't started building mine yet, just saving the parts up Building: RB7 Nitro / Senna MP4/4 Finished: McLaren MP4/23 Brad.
Thanks Brad! Looking forward to your build! Greetings, Walter
Looking good. My pack 6 has just arrived. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Coming along nicely Dokta Spencer
Looking good.how was stage 23, the cockpit? i have just got my pack 7 and I haven't started stage 23 yet but it looks a bit fiddly? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Steve, i didn`t have any trouble building this shipment. It was the work of about 80 minutes. Much too little to do and then wait for a month again - if you ask me! :) Cheers, DaDokta Greetings, Walter
I Try to spread it out and do 1 bit each night. I can generally spread it out over 2 weeks. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Joined: 20/11/2014 Posts: 8 Points: 14 Location: bristol
wish id got mp4/4.first order,which is what I ordered.but received ,mp4/23,strange.am now trying again ,with a new order.
Guest (15)
