Canon Eyebolts Options
Tanna Ted
#1 Posted : 13 April 2014 03:57:55
Hi all,
We'll I have managed to loose about 6 canon eye bolts. Blushing They have pinged themselves into out space some where. Cursing Can anyone suggest how I could replace them without having to purchase the two issues that contained them. Confused
Ted
______________________________________________________
Current Build: HMS Sovereign of the Sea
Westy
#2 Posted : 13 April 2014 04:08:23
Rank: Newbie
How about fish hook eyelets?
George1
#3 Posted : 13 April 2014 04:26:13
Tanna Ted wrote:
Hi all,
Hi Ted.
I had similar problem losing one of them never to be seen again. Laugh
You can purchase very thin tie wire that you could make up eye bolts perhaps and paint brass colour later.
I was thinking same as you just how critical the number of these eye bolts are and whether there were any extras in the issues because of that problem of wanting to fly off into space?Confused
Seems a little expensive to have to purchase back issues just for the eye bolts. Perhaps some of the long time members may be able to throw some better light on your question. BigGrin
George1
Building HMS SOTS
George1
#4 Posted : 13 April 2014 04:37:24
Hi Westy
Welcome to the forum.BigGrin
George1
Building HMS SOTS
jock
#5 Posted : 13 April 2014 05:16:23
I place a rag over the pliers when using side cutters, my shed floor is covered with spares I usually vacuum regally then sift the wast.
Previous builds
Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour
http://jockspage.webs.com/
Tanna Ted
#6 Posted : 13 April 2014 06:25:59
Hi Westy,
Welcome to the forum. I like the idea of the fish hook eyes. Thanks for the idea.
Ted
Tanna Ted
#7 Posted : 13 April 2014 06:27:17
Thanks guys for the input. Appreciate it.
Ted
#8 Posted : 13 April 2014 07:24:22
BigGrin Fish hooks size 20 are the ones you need . And to stop them pinging of I tend to make them inside a large box ThumpUp to stop the carpet gremlin eating them BigGrin Ps welcome to the forum rgd Martyn
Tanna Ted
#9 Posted : 13 April 2014 09:08:54
Hi Martyn,
Thanks for that I'll go and get some. Your right about the carpet gremlin.
Ted
Tanna Ted
#10 Posted : 14 April 2014 11:19:27
Hi Martyn's,
The fish hooks worked a treat. Paint them bronze and whalla. Cost a dollar. Used the long shank as they don't have bend in them. Thanks mate.
Ted
George1
#11 Posted : 15 April 2014 05:40:14
Hi Ted
Pleased to see you were successful re fishhooks.Cool
I've put into my notes if required.BigGrin
Found out something else that's handy and that's the wire tying of the blocks re the loops and handling because they are so tiny.
I kept losing them on the floor.Laugh
If you look on Build Discussion you'll see question "Efficient way to make up blocks".
karl1113 shed some light on it that I think is the answer and I will do as he suggests. His reply answer is simple when you think about it.BigGrin
If you are not having any problems with handling them then no worries. Thought I'd just pass on if any help in future.
George1
Building HMS SOTS
harvardhound
#12 Posted : 15 April 2014 06:49:17
Hello
I'm on issue 40 and I have a small bag of spares from the cannons which I'm sure includes a couple of the eye bolts
Not sure if this is due to picking errors or to take into account the likelihood of us losing a couple of small bits but hopefully you will have the same 'extras''
Paul
Building - Sovereign Of The Seas
George1
#13 Posted : 15 April 2014 08:15:32
harvardhound wrote:
Hello
Paul
Hi harvardhound
That's good to know. Cool
I sort of felt that they would put some extras in from previous model builders registered problems in the same area. We're only up to issue 5 re newsagents supply so had no way of knowing.
Regards and thanks. BigGrin
George1
Building HMS SOTS
bluedot0
#14 Posted : 15 April 2014 08:38:36
Hi everyone
An possible alternative to fish hooks, is to use HO scale wire lift rings from Details West, these are sold in packs of 24 and are used to detail locomotives.
The scale of these rings is 1:87, which is almost the same at the SoTS 1:84 and they are already formed, see the link attached, you can get them from good model train shops or Ebay or direct from the US.
Phil
http://www.internettrain...CDETDTALFT&Featured=
You only live once, but if you work it right, once is enough.
Building - Bismarck, Akagi, Warspite, Gato, USS Enterprise (carrier) and D51
Tanna Ted
#15 Posted : 15 April 2014 11:42:30
Hi Phil,
Thanks for the hint. I'll look into that for future pinging eye bolts
Ted
Tanna Ted
#16 Posted : 15 April 2014 11:47:54
Hi George,
Yes I saw Karl's reply to your question. I'll be trying that, but I'm going to wait until I have all the cannons and do them in one hit
Ted
Shaky
#17 Posted : 17 April 2014 15:26:28
I may have an answer. Try a fly tying clamp(for fishing flies). Lets you hold the items and pass things around them etc. I am using one just to hold things.
Cheers
Peter
Tanna Ted
#18 Posted : 18 April 2014 03:41:38
Hi Shakey,
Sounds like a good idea. Never used fly equipment, where in get one Confused
Ted
Shaky
#19 Posted : 20 April 2014 17:14:43
Ted,
Most angling shops will have a fly tying clamp. Mine is a cheap table top one that clamps to the table and swivels so that you tie threads on the fly at various angles. You wouldn't swing Queen Mary of it, but is a useful tool. I have also used to set gemstones in earings etc.
Cheers
#20 Posted : 20 April 2014 17:51:43
BigGrin Glad to be of help Ted . Thats what's bril about this forum lots of help if you need it BigGrin Happy building rgd Martyn
This page was generated in 0.541 seconds.
