Can someone suggest a good toolkit to build with ? Also when I was building the MP 4 23 the most trouble I had was assembling the rear wing ! ,having seen the MP 4/4 it's a much more simple arrangement 😀 so it should ( fingers crossed) be easier to assemble.is it worth buying the slide sheet decals of the monocoque ?
Hi Al There is no tool kit as such for this kit but some good needle files and glues are essential for any model enthusiast. As for the decals for the monocoque? That's a personal decision if you want to enhance your build. Spencer
Cheers for that ,ive sourced a tool kit and ive got the full sponsor decals
